jmiemiec's Avatar
SC cams - is that all??
Hi, I recently installed new SC cams. Motor is a 1974 2.7s. I cant feel any real 'upgrade' differences aside the fact that the motor revs a tiny bit lower on same speeds. Is that all that one is to get from this upgrade? Is there a way to check aside a dyno?
thanks guys.
JM.
Old 03-31-2009, 04:55 AM
Halm's Avatar
First, you may want to move this to the 911 forum.
But I'll venture a guess: You wanted 964 cams on your 2.7 (assuming it still has CIS), not SC cams.
'17 Cayenne
Old 03-31-2009, 07:43 AM
a.k.a. G-man
Geronimo '74's Avatar
I'm guessing the same... bummer...
Old 03-31-2009, 08:48 AM
kodioneill's Avatar
i put 964 (s for cis) cams in my 74 made a huge difference.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-31-2009, 08:51 AM
Send a message via Yahoo to jjrowe
I noticed a big difference when I put SC cams on my 76, a generally stronger pull at all RPMs. My guess is your CAM timing isn't set correctly. From what I've read you won't see much difference between the late style SC and 964 cams (on that motor anyway), so I think its something else. Do you know what your CAMS are timed at? Who ground them?
Jesse
76 911 S
Old 03-31-2009, 09:24 AM
jmiemiec's Avatar
JJrowe, if you had to take a wild guess for torque % increase on your SC cams, what would that be across the range? I currently only see a drop in revs e.g. -200rpm to reach 120km/h.
Old 03-31-2009, 09:35 AM
Hmm, as a wild guess I would say that I notice almost no difference (0-1500), then it starts to pick up and between 3000-4000 I would say as much as 10% more torque. I also am now running stock exhaust and before the switch I had headers. I am keeping the stock exhaust on now because I don't feel like I need the headers anymore.
Also there were variations of the cams on the SCs, the later style was used after 1984 I think. That is what I have.
You definitely should notice a difference!
-Jesse
Old 03-31-2009, 09:48 AM
-Jesse
All SC cams are identical. Only timing variations were made depending on the model and year.
Cheers,
Joe
74 911 w/ 86 3.2 conversion
Old 03-31-2009, 09:55 AM
ianc's Avatar
You will not see any drop in RPM's to reach a specific speed. That is related to the transmission's gear and final drive rations, which haven't changed.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 03-31-2009, 10:06 AM
Somatic Negative Optimist
Gunter's Avatar
Question
thanks guys.
JM.
What cam timing did you use?
Also, the '74-'77 cams for the 2.7 liters have 3 bearings and the SC cams have 4.
How can an SC cam fit into the 2.7 liter cam towers?
Thanks.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-31-2009, 10:33 AM
Air Medal or two
afterburn 549's Avatar
Mine was HUGE , B4 it was way too peaky, came on way at the top. Now a much steadier pull.
@ the time I did not know about 964 cams that would be better
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-31-2009, 11:05 AM
dtw dtw is offline
GAFB
Cam change won't affect engine speed w/r/t vehicle speed. Only gearing changes (including tire size change) will do that.
Several BMWs
Old 03-31-2009, 11:26 AM
Air Medal or two
?????? Must effect something or people would not do it.
To take your statement to the extreme.. a flat cam, or wrong cam, or wrong timed cam will not improve your eng performance or your car speed.
A "right" cam will
So that's what i think, brought to you from dwn twn Juneau where all the girls frigid and the cars are a pity
The more I think about this.... I am right cause you actually change the CFM the eng works with
that's why head porting valve size and volumes are experimented with all the time..Not just in the P world
Old 03-31-2009, 11:33 AM
Gunter's Avatar
So, How can a 4-bearing SC cam fit into the 2.7 liter 3-bearing cam towers?
Old 03-31-2009, 12:37 PM
Air Medal or two
I think just change the towers
Old 03-31-2009, 12:38 PM
Halm's Avatar
A good file and a lot of elbow grease?
'17 Cayenne
Old 03-31-2009, 12:42 PM
The lobes on the 3 bearing cams are welded and reground to match the profile of the 4 bearing SC cams. This is a good option for the 2.7s because Porsche seemed to get the CIS cam profile optimized by the end of the SC era. I really noticed a nice improvement.
- Jesse
Old 03-31-2009, 05:03 PM
Air Medal or two
Thanks jjrowe,
I remember having a heated discussion with the cam person i was using...at that time they did not think 964 would work....Now I know they would
Old 03-31-2009, 06:53 PM
The CIS intake limits the amount of cam duration due to revision and the effect upon the fuel metering.
The stock 2.7 cam runs 224 degrees of intake duration, the SC through carrera cams run 234 degrees of intake timing.
Expecting a big improvement from a simple 10 degree's of additional intake duration without any other improvements is not realistic.
By comparison Solex cams from the early '65 911's run 248 degrees and the "S" cams on the Weber equipped 67/68 911's ran 268 degrees of intake duration.
If you want decent performance from your 2.7, get rid of the CIS, add some 40 Webers, higher compression pistons, open up the exhaust system, and install Solex cams for street use. "S" cams for the track. Dual plug ignition is a great upgrade as well.
Another tact is to dump the 2.7 and go for a larger engine, your choice and budget.
Back dating my transaxle to a 7:31 ring and pinion added substantialy to street performance, at the cost of high end, 125mph plus, speed.
Doug
Was 2.7racer.
'76, 2.7 w/Webers, JE pistons, Solex cams. Elephant bushings front & rear, 23mm & 28mm torsion bars, big brakes front & rear, Pertronix. Track car.
'85 3.2 stock, Orient red, comfy street car.
Old 03-31-2009, 07:30 PM
I am not an expert but is it an S or normal 2.7. The non S has very small ports and lower compression and a bigger cam is not going to help much. What is going on on the exaust side? For the cams to reach there potental you need a 74 style exaust at a mininum. A sport muffler would make it all the better. Also, I think you need to increase the valve spring tension with such a change to keep the rockers on the cam with its more aggressive lift angles.
I would not expect more than about 10-15 hp from the cams. C2 cams with 36mm ports, 9.5 compression ratio pistions, and sport muffler should get you close to 200hp I would guess.
Old 03-31-2009, 08:07 PM
