-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   wipers not parking no intermittent wipers (http://forums.pelicanparts.com/showthread.php?t=471810)
Dkennel 04-29-2009 06:45 PM
I have searched the board for quite a while to figure out my wiper problem: they don't automatically park, just stop wherever I turn the switch off and my intermittent wiper setting does not work.
I expected the wiper switch to be the problem and finally took the time to pull it all apart. I could not get the wipers to park! they still stop wherever....
I thought maybe it is a bad contact in the switch and "jumped" the blue and black cable from the contacts that should make them park, no fix!
So what is my problem then? Is it in the wiper motor? Can anybody help me with this, I thought for sure the switch would be the answer from what was posted before....
Dkennel 04-29-2009 07:24 PM
Can a defective wiper motor relay cause this problem?
All other wiper functions work slow/ medium/ fast/ spray, just no park, no intermittent???
NineOhOne 04-29-2009 07:27 PM
See: http://forums.pelicanparts.com/showthread.php?t=426241&highlight=wiper+relay
Dkennel 04-29-2009 07:38 PM
I have read that thread, it does not apply to my car, I think the 87 has only one wiper relay. I found a thread that suggests my problems could be the relay, others say if just the relay is defective wipers should still park???
Dkennel 04-29-2009 07:39 PM
how about this:
The following was provided by Jason Savage (jsavage@crystal.cirrus.com).
Intermittent Wipers
Problem:
'89 Carrera (not a C2 or C4) with intermittent wiper dial. Up until the failure, the intermittent wipers worked fine, and the wipers would park in the correct position regardless of when you turned the intermittent wipers off. The continuous wipers also worked fine, and would park in the correct position even if you turned the wipers off in the middle of a wipe. During my drive to work in a light drizzle one morning, the intermittent wipers had been on for about 30 minutes and were working fine, when all of a sudden they switched into continuous wiping mode. When I turned the intermittent dial off, the wipers would stop wherever they were at, and would not return to the park position. I also noticed that the continuous wiper mode also lost its ability to park the wipers properly. In order to have an unobstructed view when the wipers were off, I would have to time when I turned them off so that the blades were somewhat near the park position.
Solution:
NOTE: SPECIAL THANKS GOES OUT TO CHRIS BENNET FOR THIS SECTION. THE MAJORITY OF THE INSTRUCTIONS BELOW ARE HIS, WITH A FEW COMMENTS OF MINE ADDED IN.
Tools: 7mm, 8mm, and 10mm socket, socket driver, 10 mm wrench, phillips screwdriver, flat head screwdriver (for prying relay open).
Getting in there:
Removing the hoses and air box is very easy. Review the following instructions before starting, and you will be at the relay in less than an hour, even if you go really slow. There is no difficulty in performing this job yourself - the second time you have to do it (hopefully on someone else's car), you can get to the relay in 10 minutes or less. Here is the tricky part - the fresh air box is fastened to the car via two "hidden" screws located under the black screen for the fresh air inlet (see STEP 5). If you face the windshield (while standing outside the car with the trunk closed) and look behind the black screen, you can already spot the two screws.
Here are some highlights of the disassembly:
NOTE: All directions are relative to sitting in the trunk, facing the windshield.
STEP 1:
I used a socket driver to remove (most) of the hose clamps (7mm). I ended up completely removing the 2 hoses on the left side, and the one closest to me on the right side, i.e. the one connected to the right side of the blower motor.
STEP 2:
The plastic "Y" shaped hose joint (in the center of the car, just below the blower motor) that goes into the floor of the trunk of the car is held in place by a phillips head screw that you can see - the back of that "Y" shaped hose joint is just held down by a clip that it slides under. I.E. Unscrew the little screw connecting joint to floor and pull the joint toward you. Stuff a rag in the hole so you don't loose something down there. The hose connected to the right side of this "Y" shaped hose joint is pretty long, and can remain attached to it during your work. Just move the joint/hose to the right and out of your way.
STEP 3:
To get that brace on the right out of the way you have 2 options: 1 - remove the vacuum hose blocking the bottom bolt, then loosen the bolt (10mm) about a 1/2 turn. 2 - using a 10mm wrench, squeeze the wrench in between the vacuum hose and loosen the bolt about a 1/2 turn. By loosening the bottom bolt on the brace, you can remove the brace's top bolt (10mm) and swing the brace out of the way.
STEP 4:
Remove the top half of the blower assembly (2 screws, 8mm), unplug the blower and swing the top half of the blower assembly out of the way. You can't remove it completely out of the way because it has a control cable attached to it.
STEP 5:
Remove the cover that holds down the black screen that covers the fresh air inlet (4 phillips head screws). Once the cover and black screen are removed, you can now get to those two top ("hidden") screws and pull the plastic blower assembly down. The assembly may still seem fastened to your car, depending on how long it has been sitting in there. Here is why: There is a rubber (grommet?) along the perimeter of the assembly where it is pushed into the area nearest the air inlet is (i.e. the area where the black screen used to be). You are basically breaking that n-year old seal. The trick is to wiggle/push on the assembly with a force that is in the same direction as the two "hidden" screws you just loosened. It helps to first disconnect the drain pipe located at the bottom of the assembly before applying any force, so that you are not working against the drain pipe.
STEP 6:
Once the plastic blower assembly is out of your way, you can see the intermittent wiper relay. It is part #911.618.149.01 for model years '76-'89, and part #911.618.149.00 for '74-'75 models. In my car, it is just to the right of a blue, slightly larger module that is part of the factory alarm system. If this is the same thing you see in your car, here's another trick: there is a section of the wiring harness running between the alarm module and the intermittent wiper relay. You have to pull up this harness slightly to get to the nut beneath it that fastens both modules to the firewall. Once this nut is off, you can get the relay module out of the car out by unplugging it from its connector.
STEP 7:
With the relay out, pry it out of its case by using a flat head screwdriver. The contents of the relay module slide out on a little printed circuit board, and all you have to do is clean the relay contacts by gently sliding some 150grit (or finer) sandpaper in between them. I also sprayed some contact cleaner in there (the stuff Radio Shack sells for $7.99 for cleaning up stereo volume knobs, tv dials, etc). This stuff does not evaporate easily, so I spent some time wiping excess contact cleaner off the rest of the circuit.
Before reinstalling the relay, I performed some testing per Chris's request:
I. With the relay out of the car, I turned on the continuous wipers. They will turn on, but still will not return to the park position when you turn them off.
II. As expected, nothing happens when you turn on the intermittent wiper dial.
After reinstalling the relay, but before putting the fresh air system back together, I observed the following:
I. Everything works: intermittent wipers, continuous wipers, and park functionality.
STEP 8: To quote the Hayne's manual, "reinstallation is the reverse of removal," but please learn from my mistake: don't forget to reconnect the drain pipe (mentioned at the bottom of STEP 5) to the plastic blower assembly before you focus your efforts on getting the blower/rubber grommet positioned back into the car.
jonbot 04-29-2009 08:37 PM
Dude, I had the same problem, it was in the wiper switch. When it goes back to it's "off" position, there's a set of contacts that close in order to leave power to:
a) park the wipers
b) run the intermittent wipers
I know you said you checked this, but I still think the problem is related to that.
Mothy 04-29-2009 10:42 PM
I also have the same problem with one subtle difference.
I only have speeds 2 and 3 for the wiper - speed 1 does not work, the parking function does not work and the intermittent wiper function does not work.
From the research I have done (still to be confirmed by taking out and checking) the problem is that my wiper motor has lost its low speed setting. The parking function uses this speed as does the intermittent wiper switch. I've checked and tested the switch and it works fine.
I'll let you know how I go. Planning to take it out this weekend.
Tim
wings911 04-30-2009 02:30 AM
Had similar problem on 81SC
Normal wipe wouldn't park. If I switched on the intermittent, I could only stop them by switching the wipers on then off again on the stalk.
Boiled down to a combination of a broken connection in the intermittent relay and also broken rings on the motor itself
HTH...
Rick V 04-30-2009 02:54 AM
You need a wiper motor. The park feature is in the motor.
Mark Wilson 04-30-2009 03:48 AM
Most likely contacts in the switch have arced and are stuck together.. My 79 did exactly the same thing. It's a very common problem and there are a lot of threads on it.
Poor-sche Lover 04-30-2009 08:48 AM
I concur with jonbot and Mark. Mine was exhibiting the exact same symptoms. The contacts in the switch inside the steering column had gotten gummed up and weren't making a good connection. The intermittent wiper switch on the dash will not work unless the wipers properly park. They will not properly park unless the column swtich parks them. If you clean the contacts, everything should work fine.
911Texan 02-29-2012 06:15 PM
I've got to troubleshoot the the EXACT same issue described by multiple Pelicans above. The relevant portion of my Haynes "current flow" diagram for my '84T shows the following:
http://forums.pelicanparts.com/uploa...1330571131.jpg
Anyone want to interpret why I have NO int wipers at all (switch/rheostat do NOTHING) and windshield wipers do not park. I do not see how the "low speed" of the motor is to remain "hot" to enable the park function as mentioned above. In fact, when the wiper switch is in the OFF position, the only thing I see powered is the intermittent "pulse transformer." I do not see how the "pulse transformer" even gets 12V to the wiper motor either. I can't figure out the nomenclature for that windshield wiper motor.
Yeah, I'll clean up contacts and stuff like that, but man it would be nice to have a theory based on the wiring diagram before I start.
- Rich
Mothy 02-29-2012 11:10 PM
In my case it turned out to be the power connection on the motor for lowest speed setting. Turns out autopark, intermittent and low speed all used the same lead - and it had come loose in the multi pin connector.
kanadary 03-01-2012 05:09 AM
i had the same issue and it turned out to be the switch. someone wrote a nice article on here about how to clean the switch. i ended up replacing it and its fine.
ivangene 03-01-2012 06:00 AM
when you turn them off - try a tiny pressure on the wiper lever....see if they go and park....
I found that if I just touch the arm it would move...or try a lightly wrapped rubber band from the cruise arm to the wiper arm and see if they work right....
I swear that actually worked for me...after a few weeks with the rubber band I took it off and they work fine (over a year) So must be a problem with the switch but until it completely fails or I land one cheap...if it happens, I just put the rubber band on for another couple days...
cheap fix
Hugh R 03-01-2012 09:00 AM
For me it was the switch. I took it apart, cleaned the contacts and it worked fine. The intermittent switch can't work unless they park first.
sparkle84 03-01-2012 03:14 PM
This is a common problem & is usually related to the switch not the motor. Ivangene has the right idea. When turning the wipers off exert forward pressure on the stalk. You may have to push fairly hard. When I found that pushing forward worked I also had the rubber band idea but it didn't supply enough pressure. If the wipers park when you shut them off while pushing forward then it's the switch. Cleaning it won't necessarily do the trick. The contact could be bent thru years of use. Just has to be bent back. At this point I don't remember if pushing forward causes the contacts to close or remain open. either way if you remove the wheel & clamshell & observe which contacts change their behavior when you push forward & don't push forward you will see immediately what the problem is. If I remember correctly it's the ones closest to the dashboard. So if pushing forward works then that's the problem. Quick easy fix & best of all...no $$$$. Your intermittent feature will also work again.
Good Luck
Dkennel 02-23-2013 07:34 PM
I am reviving this thread. It's been very dry in Texas did not use my wipers much. I started taking my dashpad off, so I removed the air intake and the blower motor. Now I also have good access to the wiper relay and the motor. I also took the steering wheel off since I need to replace the turn signal/headlight stalk switch. I took a real close look at the wiper switch while I am there:
I think my wiper switch is fine, don't see anything that doesn't look right with it. The connector to the intermittent wiper relay looked like it may not have been pushed in all the way??? kind of crooked so I pushed it in and wiggled a little to make sure I have good contact, so now I have this going on:
I can run intermittent wipers with the potentiometer switch between the gauges. The wipers park fine and the interval function works great. If I have intermittent wipers turned on I can also turn the wipers on with the stalk switch and get all three speeds, as long as the intermittent potentiometer is turned on the wipers will also park. If I turn the potentiometer to off position the wipers will park anywhere on the windshield if I turn them off with the stalk.
Can somebody tell me if this is normal? Seems like a dumb question, but do the wipers only park if you have the intermittent wiper switch in on position? If not what is not working right?
spuggy 02-24-2013 10:23 AM
Not normal.
For the wipers to park, the circuit needs a ground. As described above, there's more than one thing that can go wrong with this...
From your description, it sounds like you have a ground when the intermittent switch is on, but not otherwise. This isn't the way it usually goes... Try moving the stalk around and see if they park.
Dkennel 03-01-2013 07:13 AM
ok, I had enough of this and ordered a new wiper switch, everything had pointed that direction....
new switch is installed....same problem:
wipers do not park when turned on and off on stalk switch, intervals work fine and park fine!! when the interval switch is slightly turned on the wipers also park on stalk switch...
As spuggy suggested it seems I am not getting ground contact when I use the stalk switch, where do I need to look for that ground connector? I have everything apart right now, including fresh air blower to get access to wiper motor...
any suggestions? It is not the stalk switch, not the motor (wipers park fine on intermittent), not the relay(?), probably a concoction - poor ground?
Dkennel 03-01-2013 08:06 AM
Problem Solved!
I finally had enough of this... jsavage was right on this:
I removed the intermittent wiper relais (it is a pain to get it off, mounting screw is hidden, tough access 8mm nut) and pried the relais apart, to my disappointment there was no dirt or anything visually damaged inside, I moved the contact a little and gave it a puff of contact spray, reconnected everything and wow(!!!!!): everything works! Intermittent wipers run and park, stalk switch runs all three speeds and parks!
Bottom line: all the no parking problems can sometimes be the intermittent relays, cleaning contacts here worked for me. (BTW I have a used wiper stalk switch for sale now, LOL)
Dkennel 03-01-2013 08:21 AM
jsavage was right!
I pulled my intermittent wiper relais, pried the the case apart and gave it a puff of contact cleaner...
Everything works, wipers park with stalk switch, intermittent wipers work. I am ready for rain!!!
http://forums.pelicanparts.com/uploa...1362158182.jpg
wiper relais is behind the fresh air blower, it is mounted with an 8mm nut below the cable harness to the left of it (a major pain to get off)
http://forums.pelicanparts.com/uploa...1362158207.jpgIf you are more careful you can pull the relais apart without breaking the housing...plastic is pretty brittle though. There was no visible dirt inside, I just gave it a puff of contact cleaner and cleaned the plug connectors and now everything works....
It is not always the wiper switch contacts that cause you to loose parking, relais was definitely my cause!
White86Cab 03-01-2013 02:06 PM
Just replaced my Intermittent wiper relay located behind the fresh air blower. Fixed the problem wipers were erratic on intermittent, didn't park sometimes, and when I used the windshield washers they would wipe only once instead of three times.
James Brown 03-01-2013 02:49 PM
sometimes the wiper contacts in the stalk get misaligned, if you can push on the wiper switch forward and everything works fine (wipers park, intermittent wipers work) than a little bending of the contacts is in order. John Walker has a good article on how to do this
Dkennel 03-01-2013 05:24 PM
I tried the stalk alignment twice and finally replaced the stalk switch, but it did not fix my problem. Cleaning the intermittent relay was the way to fix my park problem.
atc_marty 05-22-2013 11:43 AM
Just performed the relay clean, my wipers now park thanks to this thread! I also reversed the wipers while I was in there. Now I just need to replace the wiper stalk on the steering column, it only responds to the washer fluid function.
Jfporco 11-19-2013 04:29 AM
Reviving this not too old thread. Just finished repairing the major issue with my wipers (not working at all), now I am chasing the 'will not park' gremlin. The instructions were very helpful from Dkennel, especially the fresh air inlet hiding the two bolts of the blower. Wiring diagrams helped put it all back together at 2:00 this morning. Now with proper lube she works great.
Thanks Pelicans for saving my pocketbook yet again!
Cheers,
Porsche Driver 08-13-2015 05:59 AM
My fix for 911 wiper park issue
Thanks to my posts on pelican I was able to solve some electric issues on my car so to be fair I wanted to share my fix to a couple of wiper related issues and intermitted function.
Reconnect battery
1) I replaced the wiper switch iteself as it had to much play.. After a speedbump it would start wiping.. Problem solved with new switch
2) I checked the relais by turning the intermitted switch ( remove the clock and you can hear it mich better!). If clicking.. Stop buying a relais to test as it's likely to work. Nevertheless, i opened it ( first remove the blower etc..) and cleaned the contacts with some 400 grit sandpaper)
3) so switch, relay and intermitted excluded by the cause of my wipers not parking correctly.. Had to switch it off manually and in intermitted mode it would park in the middle.
4) now the wiper engine is the next one to look at.. Pain to remove with big hands.. And note down where the wires go! ( i tend to make a picture before removing anything). There are three bolts on the frame you can access via hood, 1 central nut that connects to wiper mechanism and two screws you get to by removing clock and speedo... How easy ;-)
5) I first looked at electric wires and the blue is the one that relates to park position! So... Connection wasn't great so I did reconnect again freshly
6) I opened the gearbox to see if any grease is stuck, looked ok, but cleaned it and put fresh grease in the... I cleaned the metal carefully and Slightly bent the three metal connectors and clean them with 400 sandpaper... Close it up, don't forget the gasket and then gradually tighten the screws crosswise
7) reverse..build in and connect the wires
8) reconnect the battery and in my case i heard the engine move a litte inside
9) solved!! Wipers, intermitted and park are fully operational... Main case of all this was a loose blue wire on the wiper enginehttp://forums.pelicanparts.com/uploa...1439474278.jpg
http://forums.pelicanparts.com/uploa...1439474314.jpg
scbates930 09-27-2021 12:48 PM
Cleaning the relay contacts fixed my non-parking wipers.
NICE 69 S 09-27-2021 01:22 PM
wipers don't park
Pretty sure some of the parking problems are in the motor. When you turn off the wipers, there is a wire that is always hot that goes into the gearbox. Inside the gearbox you will find two or three contacts that sit on copper tracks on the gear. When you turn off the motor (or have it on intermittent) the contact sends 12V to a track on the wheel that carries the motor to the park position (no copper track as seen on the outside upper left of the gear in picture above, and red wire in same picture), then it stops.
When you turn the motor on, 12V comes in on another wire and contact to start the motor and move it off the park position.
So one of two things, the wire that is supposed to be hot all the time has no 12V, or the contact on the gear that carries the motor to park has lost its connection.
Bob B
ChrisBennet 09-28-2021 02:05 AM
I had a problem with my wipers just parking whenever I turned them off. They also wouldn’t stop wiping if I turned the knob.
Turns out, I had a bad wiper relay. My electrical engineering friend visually determined that it had a bad electrolytic capacitor. He replaced the capacitor and everything works again. (Relay is for a 1986 911.)
