jack for lowered porsche
Does anyone have recommendations for a jack? My 78 is pretty low and cant seem to find a jack that is long enough and low enough.
I use this one
My car is not terribly low but it has worked well.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40105 Best of luck, Bryan |
You don't need a jack, you need these:
http://www.pelicanparts.com/catalog/...L-TOL-JKPD.jpg http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=55-6641-030-M230 |
Can you lift the front end as well?
Use the aforementioned jack pad and two standard-type jacks, nothing special:
1. An inexpensive scissors jack under the side to lift one side high enough to use a..... 2. Standard floor jack in whatever flavor you prefer that lasts the longest. My inexpensive scissors jack is a hydraulic unit from HF, <$20. This procedure doesn't require special tools other than the $10 lift pad. Sherwood |
Check this out - $100 off at Amazon now:
Advanced Tool Design Model ATD-7325 2 Ton Extra Low Profile Tuner Jack |
Too bad the long frame, low profile jack is NLA at Pelican. Not dissing PP, it's NLA everywhere.
Northern Tools has a similar unit. |
+ 1 on the jack plate and Harbor freight combo
I recently purchased an Arcan XL35 from Costco for about $95. It's a 3.5 ton jack, long and low.
After having 2 of the cheap Harbor Freight jacks bend and come close to dropping a car, I just cut some pieces of 2x10 lumber stacked 2 pieces high, and with one end beveled. I just drive up on the "ramps" then have room under the front to get my good jack under the car. Cheaper than buying a new jack.
Cheap and effective. Roll the car up on some foot long 2x6's. Should get the car up high enough to get a jack under it.
snodgrass
you are a genius! Its kinda like that experiment with the monkey, the jar of peanuts and the hand getting stuck inside looking forward to jacking the car up |
sorry
you too Ed |
If you don't know what you're doing, yes, you can get hurt, or hurt your car. Spending more money on a jack won't prevent that. |
Moral- Being in a hurry when working on a track car is never a good idea. It'll always come back to haunt you. Second moral- just get a good sturdy jack and use it rather than the cheap stuff. |
I forgot what my big HD jack I keep at home is. I bought a Sears alum jack to put in the trailer and it's been pretty sturdy so far.
If you're looking for one to carry in the frunk, go to an auto wrecker and get one out of an Audi. They go very low and are stout. Rob
| All times are GMT -8. The time now is 04:52 PM. |
