Uncertifiable!!!
Uwon's Avatar
[QUOTE=Bigtoe32067;11026825]
Originally Posted by Villeneuve27 View Post
Here's mine, with Bilstein shocks all around + Bilstein struts with 19mm raised spindles.
7" and 8"x 15" Fuchs with 205/60 front and 225/60 rear.
That car looks menacing, in a good way. I love the stance.
Can you REALLY turn the front wheels without catching the fenders while going over a bump?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-16-2020, 04:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2761 (permalink)
xjoegtix's Avatar
My rig.
Old 09-16-2020, 06:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2762 (permalink)
Behind the Sun
xjoegtix
Can you post normal size pics so we can actually see them
Thanks!
Old 09-16-2020, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2763 (permalink)
356RS's Avatar
Just use your mouse/finger to move the photo around. Great photo BTY.
Mark Jung
Bend, OR
MFI Werks.com
Old 09-16-2020, 08:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2764 (permalink)
scumbag
Johan
Johan,
You would be surprised how easily the fronts clear with rolled fenders, a little offset magic, and properly sized tires. I drive mine like a rental and have yet to rub.
Joe,
Your car is impeccable as always.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2765 (permalink)
nameisbauer's Avatar
Send a message via AIM to nameisbauer
@heyitzsushiboi Fire.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 09-16-2020, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2766 (permalink)
[QUOTE=Uwon;11027882]
Johan
YES, NO PROBLEM!!!
Old 09-17-2020, 12:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2767 (permalink)
Competizione's Avatar
Old 09-18-2020, 07:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2768 (permalink)
David 23's Avatar
I love the look, but honestly, I just don't see how you are able to drive this car hard, really loading the suspension and not get rub. What are your suspension specs? I know you said you don't catch the front fenders when turning hard and in a bump, but I just don't see how with that little amount of clearance. I assume the fender lips are folded pretty flat on the inside? Don't misunderstand my post, I love it, I just am curious about how you pull it off.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 09-18-2020, 07:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2769 (permalink)
scumbag
In the first pic you quoted, notice the ~1" (25mm) shadow between the fender lip and tire.
This does two things.
1. It gives the illusion that the fender and tire are closer than they really are.
2. It proves that they are not close. If the tire were right up to the edge of the fender, there would be no shadow. Case in point: Look at the rear wheel in the same picture. At 9 o'clock, there is no shadow between fender and tire as they are in nearly the same plane.
Assuming this car has any roll/bump correction, then there will be camber-gain on compression and the top of the wheel will move in under compression.
When you combine all these things with a reasonable scrub-radius, the wheel/tire will twist/pivot instead of swing when the wheels are turned. This also helps keep the tires off the arches.
I will assume the fenders are rolled as the car looks to be very well put together. This also contributes ~1/2" (13mm) of clearance.
None of this is sorcery. It's a little math and a little trial and error.
Old 09-18-2020, 11:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2770 (permalink)
And a little Photoshop....
Old 09-18-2020, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2771 (permalink)
scumbag
rude.
Old 09-18-2020, 01:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2772 (permalink)
rude.
Sorry. But those pics are shop'd.
Old 09-18-2020, 03:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2773 (permalink)
Stonestreet's Avatar
While at the shop today, a delivery truck pulled in and parked behind me. It was close to perfect. I wanted to share this pic because you folks are probably the only people who care.
7" & 8" x 15" wrapped in 195/65 and 205/60 with 21mm spacers in the rear. I measure 25 ⅝" to the lip on the drivers side rear and 25" on the passenger side rear. Is that normal? Also, the mechanic that I know and love doesn't really want me to drop the car any lower, but I see so many that seem lower.
I recently pulled the chin spoiler and tail, as I'm sure many will notice from the lack of wrap where the footprint of the chin resided. I also plasti dipped the wheels to try something different. I'm into it. Anyway, thought it was a cool pic.
Old 09-18-2020, 05:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2774 (permalink)
Originally Posted by Stonestreet View Post
Really like this stance. What suspension did you go with?
Old 09-18-2020, 08:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2775 (permalink)
@Ocean, it's stock.
Old 09-19-2020, 04:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2776 (permalink)
Nice capture.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 09-19-2020, 08:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2777 (permalink)
scumbag
They must be really good at photoshop, because the video looks to be the same height.
https://www.instagram.com/p/CEVyQwPqa30/?utm_source=ig_web_button_share_sheet
Old 09-21-2020, 05:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2778 (permalink)
msmall215's Avatar
Mike
'85 3.2C
IG: @msmall90 | @zuffenphilly | @ruchlosrallye
Old 09-21-2020, 07:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2779 (permalink)
Mr. Merk's Avatar
Originally Posted by msmall215 View Post
Dialed
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 09-21-2020, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2780 (permalink)
Tags
california sucks.
