Oil Pressure Warning Light Adapter
I'm busy tracking down an oil leak and haven't been able to fix it yet. So far I've changed the crankcase breather gasket, thermostat o-ring and the oil pressure idiot light sensor. It still looks like I have a leak in that area. Is it common for the adapter bolt that the sensor screws into to leak? Can you replace these adapter and washers?
Thanks Chris
1984 Porsche 911 Targa 1974 Porsche 911 Coupe- just a tub... for now
Anyone?
Pretty sure there is a crush washer on there. I put a new crush washer on mine while I was changing everything back there, just for good measure.
Silly question, but did you change the oil breather hose as well? Todd
'81 SC |
I didn't change the hose. It actually looks fairly new. It doesn't have any cracks or worn areas, so I just retightened it after I pulled it and called it good. I'll see if I can pull the adapter and put a new washer on it. Where did you get the washer? I looked on Pelican and couldn't find one.
