Gas Huffer
MichiganMike's Avatar
Todd - No MIG, actually you can spot the welder a few photos up when I posted the exhaust. We are using a Miller Diversion 180 TIG. Mat has been MIG'ing for some time now and this was his first time TIG welding!! Pretty Dimey stuff, I'd say. That bandsaw has been a huge part in this project, sorta slow but always gets it done!
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi
69 Porsche 911T - Project
04 Ford F-150 FX4 - Boris
Old 09-11-2014, 09:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #241 (permalink)
Originally Posted by Mysterytrain View Post
Personally, I would bring a 68 912 back to its original glory and find another car to bling and butcher, maybe a honda. Looks like a real nice car.
I agree. That one looks to good to mess up. 912's in good condition original condition are getting rare.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles
Old 09-11-2014, 10:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #242 (permalink)
3 restos WIP = psycho
kenikh's Avatar
^ Remember, this thread started in 2009! We were way past the point of no return, long, long ago.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-12-2014, 05:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #243 (permalink)
Send a message via AIM to ronw
wow, looks like you guys are making progress!!! great seeing you today mike and sharing the photos. i may have to steal some ideas for my phase 2 since mine is running well as it is, i just really like your crossover coolant tube angled and rotated, looks clean. why is your brother always the one dirty in the pics, i think there may be a labor inequality going on here
68 912 - R inspired 2.0L-4 turbo - sold
92 964 - C2
Old 09-27-2014, 08:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #244 (permalink)
Awesome thread and build
Old 09-28-2014, 01:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #245 (permalink)
MichiganMat's Avatar
Send a message via AIM to MichiganMat
This weekend we got to work mounting the engine in the car:
• We modified the old engine mounts to sit in the forward corners of the chassis for the cleanest "most stock" kind of install.
•*We welded up a new engine mount bar to attach to the factory mounts
• I installed a fuel return guide tube into the chassis to route the new fuel lines through
•*We started installing the silicon elbows of the cooling system and mapped out a bunch of work that needs to be done there
• We were also able to start fitting the oil coolers for the engine and trans, map out the fuel lines and pump, and took some ride height measurements.
Even though the new engine and trans combo is heavier than the old stock 912 driveline, we still seeing a solid 7" of ground clearance from the floor to the bottom of the pan.
Next up is to finish the cooling system plumbing, run and mount the oil and fuel lines, and start mounting (and likely fab'ing) an intercooler.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Old 10-20-2014, 12:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #246 (permalink)
1980SCMan
Alan Lindquist's Avatar
Just an FYI - When the CV joints hang like that (instead of being suspended by a bungie cord or chain of zip ties or...) they can and often do bend the interior flange into an oblong shape. I know - I've been there done that. If you can find a way to suspend them, you won't have this problem. As they are currently resting, it would be a good idea to release the clamp and pull back and look at the flange to see if it is bent.
Old 10-20-2014, 01:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #247 (permalink)
Max Sluiter
Flieger's Avatar
Maybe this has already been covered, but what is the weight of the Subie engine plus radiators and water compared to a 912 or type 4 engine compared to a 911?
Old 10-20-2014, 05:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #248 (permalink)
Here is what I have from the 912 board:
2.0L 911 - 405 lbs
2.2L 911 - 380-405 lbs (magnesium case dropped weight)
POLO - 286 lbs
912 - 212 lbs - 240 lbs
Subaru - 271 w/flywheel, injection, etc (but not water or radiator!), 186 for SOHC long block, 202 for DOHC long block
914 - 311 lbs? (from questionable chart)
Raby?
Pontiac 2.8 liter V6- 345-376 lb. (for point of reference, with all extras)
Old 10-20-2014, 06:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #249 (permalink)
Max Sluiter
Flieger's Avatar
Thanks.
Old 10-20-2014, 06:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #250 (permalink)
my car is about 100# heavier iirc via my corner balance scales comparing my current set up to one a few years ago with a type4 motor. the same motor as above with a WRX trans and 930 cv's for reference. I think im at 2100 now (steel body, slab sided swb with ST bar, and lighter ST/RS seats and no sound deadening.)
92 964 - C2
Old 10-20-2014, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #251 (permalink)
Had a big couple of days with the 912:
•*Mounted both the trans and engine oil coolers
•*Mounted the trans cooler pump
•*Mounted the fuel filters and pump, ran the lines
•*Painted the tank and the trunk area
•*Mounted the front bumper with a pin-and-grommet system that makes removing it a 5 minute job with very little effort
•*Finished up the front radiators (added fans, mounts, and silicon hoses, etc)
Really starting to see the light at the end of the tunnel now. We're ready to hook up the fuel system to the engine, the cooling system just needs a few more details and then its ready for water. The trans is just about ready for oil! My goodness, we're getting close... close to debugging all the fab work we've done, haha.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 12-30-2014, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #252 (permalink)
Eng-o-neer
Tremelune's Avatar
I am boggled. I hope you get the car moving with this motor, and then I hope you work the bugs out in 10k miles.
Do you expect this car to have, like, heat and what not?
Old 12-30-2014, 10:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #253 (permalink)
If you're boggled now, wait until we put it on hydraulics!
https://www.youtube.com/watch?v=X3SN-SF7oqc
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 12-31-2014, 05:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #254 (permalink)
Gas Huffer
HAHAHA!!! Well I suppose I'll start working on my mullet now.... Also, anyone know where to get white hightop Reebok sneakers?!
Old 12-31-2014, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #255 (permalink)
Eng-o-neer
Tremelune's Avatar
I thought that video was 80s at first, but I think it might just be 90s Canada/Oceana.
Old 12-31-2014, 07:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #256 (permalink)
looking good guys. I cant remember if you said you were going with a center mounted rad too. what is your total frontal area of the radiators, just curious. what are you doing for fans? just a thought, those screens look cool but i think may be too restrictive to let air pass thru. perhaps something like expanded sheet metal? keep pushing forward, your making great headway, the light at then end of the tunnel is approaching and no, its not going to take 10k to work out the bugs, maybe 9k but it'll be a fun 9k at 18lbs boost
92 964 - C2
Old 12-31-2014, 08:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #257 (permalink)
Thanks Ron, we've got a large Spal fan on each radiator and miles of aluminum tubing so Im pretty confident we'll have enough cooling capacity. We decided against a center-mounted radiator for now, but we have an extra bit of core here to fab up if we need to. For now we're going with a triple-row rad in each fender.
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
Old 12-31-2014, 08:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #258 (permalink)
RaketeRot
Draden's Avatar
Bumblebee eat your heart out. Just wait til Mike and Matt roll up at the next event and she magically transforms into a giant beer stein. Y'all be jealous
1967 911R hybrid clone
1973 911 RSR - coilovers, 2.8L twin plug RSR cam engine. butt welded metal RSR flares and metal frame ducktail
If it were easy, it would not require people of our caliber.
Old 12-31-2014, 12:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #259 (permalink)
Gas Huffer
Thanks Draden, yeah we are pretty crafty but that would be redic! Big progress though lately and looking forward to getting wiring harness soon along with that other details such as throttle cable assembly, wiring up radiator fans, mounting electronic boost controller, fab'ing up and mounting intercooler system, and of course some sort of muffling device like a muffler.... Lots to go but getting closer!!!
Old 01-08-2015, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #260 (permalink)
