I don't think 89's had CDI they had Motronic
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Ingo,
I can turn the ignition on and not start the engine and there is no hum (high pitched whine!). It only appears when the engine is running. I do not have an amplifier, it is only the head unit and it is a 1972(?) Blaupunkt. The ground is connected to several other wires that then go to ground. Could this cause the "ground loop" or is there another problem? Thanks much! Quote:
To answer TWJ: I would run a thick short wire with an eye straight to the chasis. Use a self-tapping screw into the firewall or find a machine screw that can take the ground cable. When you wire it into the brown wiring that runs behind the instruments you could end up with poor GND and that can contribute to the hum. These brown wires use spade connectors that corrode over time. And they power the instrument lights and could have several 100mV above GND.
To answer Rob: Your car has Motronic so there isn't any CDI unit. Still, make sure your head unit has a perfect GND. Same advise as above: Use a thick wire with an eye and find a chasis screw. That is the best way to get GND Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Sounds good. I will give it a shot. Thank you foe everyone's help and Good LUCK to you
TWJ in locating your troublesome hum. Rob G |
Thanks Grady, Ingo and others. I'm sure the answer is here. As always my knowledge of my car has expanded greatly because of you all!
I'll post the results. Good luck to you as well Rob G, maybe post your results for others to learn from. |
TWJ,
Have you solved the problem? I have a similar problem in an 86 911 |
You can also pick up noise...both ignition and alternator through the antenna.
To shield against this...make sure the antenna is properly grounded at the base...and also check for any resistance (no power...engine off) between the chassis or ground of the battery and the fender (where the antenna is). Sometimes rust gets into the joint and creates a non-ground issue. Hope this helps. Bob
Bob Hutson |
grounds,..grounds,..grounds..........only use one, never add them...if this doesn't help,..then I'd suspect what Ingo has suggested about alt integrity.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I reread the thread and I have exactly the same problem Rob G had. Just like for him, it started one day* and now it's always there the moment I turn on the engine. There is no hum on the radio when the engine is off. The pitch changes as my RPM change.
I looked at the ground on the radio itself and the one in the front on the passenger side. It doesn't appear to be along the hood shock going to the hood but on the inside of the fender - at least if I found the right one. I looked also at the alternator but the cables I saw looked ok. The ground on the radio could be the culprit. Instead of a shielded cable, it has a piece of metal in an L shape with multiple holes in it. On one side it is attached to the radio's ground cable entry via a shrew through one of the holes and on the other side it is shrewd to what appears to be the ground on the chassis under the dashboard. The metal is not shielded and lots of cable run around it. I wonder if that causes it. Didn't get to do it today but I'll get a shielded cable with an eye opening on both side and replace the metal. * If I recall correctly that "one day" might have been the day I took out the radio to check the connections since I had a problem with the speakers and not proper channel mapping. It could be that I did change something with the ground that now causes this sound. |
Just as an fyi: I found the cause for my problem: It was the ground cable attached to the wiring harness adapter plugged into the radio. I did check all cables and couldn't find the problem. I decided to switch the receiver for a new one that had 4 channels + sub output to the amplifier since the old one had only 2 channels output and ... the noise was gone.
So as a tip for others, check the cables for the adapter first.
___________________________________________ 1986 911 Carrera Cabriolet 3.2 Prussian Blue Metallic |
