clunking
Looking for help. I seem to be getting a clunk/clunk from the Fan/alternator area when, for example I check for fan belt tension. I don't seem to hear anything under acceleration, only when checking tension or at idle it seems to be a bit noisy but not clunking. Would alternator bearing or fan bearing be a logical guess? Or something else entirely? There are no other 911's in the immediate area to get an idea how quiet or not an idling 911 should be.
Old 09-17-2009, 10:27 AM
sudo apt-get purge 930
equality72521's Avatar
What year? Cab? Coupe?
--clutch-monkey
Old 09-17-2009, 10:35 AM
Sorry, it's an '86 Coupe
Old 09-17-2009, 10:37 AM
muck-raker
kidrock's Avatar
possibly a bearing, but it's hard to tell from the symptoms you describe. How much or how little deflection do you currently have in your fan belt? If it is less than 1/4"-1/2", your belt may be too tight and causing a strain. Removing the fan belt is simple. Check to make sure you have all 6 shims on your fan shaft. If you don't have 6, you should. If you have all 6, play around with the sequence until your fan belt has the proper tension. This may solve your problem.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-17-2009, 05:29 PM
Right now the belt is tensioned about right, but I noticed that it will clunk if I push and pull (in and out) on the pulley so I'll bet that when I take it apart tomorrow I'll find less than the right number of washers. Maybe the PO left one out. At least I hope it's that simple. Thanks for your interest.
Old 09-17-2009, 05:57 PM
unclunked (or declunked)
Pretty simple fix, as PO had 8 washers instead of 6. Now have 5 inside 1 outside and no more noise. Tried 6 inside but that was abit loose, and 5 and 1 is maybe a bit tight, but will wait awhile and check again, thanks
Old 09-19-2009, 06:50 AM
