Does my 89 (carrera, not 964) have a base/clear or a single stage?
Getting some body work done and the shop doesn't know; I'm hoping you guys can help me out.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 12-18-2009, 07:26 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
have them take a piece of 600 grit paper and scuff the panel to be repaired....if it scuffs white on the paper...it is two stage.....most all were 2 stage....if the shope doesnt know this...maybe you should choose a different shop.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 12-18-2009, 07:32 AM
Wow. No kidding...
JR
Old 12-18-2009, 07:43 AM
Friend of Warren
Wow. No kidding...
JR
+2! If it is Guards Red it is single stage. All the metallics are two stage.
Kurt V
Old 12-18-2009, 07:48 AM
Allow me to clarify: The shop thought it was a base/clear, and I had thought 911s up to 1990 were single stage.
The car's black if that helps.
89 Carrera 3.4
Old 12-18-2009, 08:26 AM
Originally Posted by Jgordon View Post
The shop thought it was a base/clear...
If the car is in the shop, it would take them less than a minute to figure this out.
Porsche didn't transition from single stage to base clear all at once...
JR
Old 12-18-2009, 08:33 AM
Formerly known as Syzygy
Canada Kev's Avatar
+3
If the shop doesn't know, look for another one. If they say it's base clear, you should probably defer to their assumed experience and knowledge. If you don't trust their juegement, why go there?
The trick with the sand paper scuffing works and will tell you without a doubt. Except if the car is white.
Kevin
Old 12-18-2009, 08:52 AM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
An easier way would be to take a mild buffing compound and rub it on the surface then wipe with a clean towel that's a different color than the car. Color on towel, single stage, no color then you'll have a nice shiny spot forcing you to buff the whole car
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 12-18-2009, 10:01 AM
