Guardsred911's Avatar
‘77 911S distributor wires- help!!
I can’t find the exact picture showing where the ring connector attaches on the wire shown- I know the spade clip goes on the right of the distributor as pictured. But does the ring connector get screwed into the flathead screw on the body of the distributor?
Thanks!
J
911 SC - 1980
911 S - 1977
Old 11-25-2025, 08:19 PM
Slightly better pict
J
911 SC - 1980
911 S - 1977
Old 11-25-2025, 08:33 PM
Eyelet connector grounds at chain housing stud.
Old 11-26-2025, 06:02 AM
Thank you!
J
911 SC - 1980
911 S - 1977
Old 11-26-2025, 07:12 AM
Does anyone have PICTs of the ring connector attached? I’m having a harder time connecting this that I should. Thank you
J
911 SC - 1980
911 S - 1977
Old 12-21-2025, 02:34 PM
Bump
J
911 SC - 1980
911 S - 1977
Old 12-23-2025, 04:39 PM
Schulisco's Avatar
This.
And the 6-3mm spade connector attaches to the ground/negative connector of the coil?
No perfect pic:
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-23-2025, 05:02 PM
thank you - still having a tough time seeing it in the pict... there isn't an obvious place for the ring connector to bolt into - a little different config than the SC pictured above (but thank you for posting that!!)
J
911 SC - 1980
911 S - 1977
Old 12-29-2025, 08:05 AM
