PVC System on a 3.2?
There is a PVC valve at the oil tank then runs thru a valve controlled by vacuum then enters just below the throttle plate as I see it. When does this control valve open to let the PVC valve open and draw a vacuum and how is it controlled? I ask because I am getting oil in my intake and it looks like it entering thru the PVC system.
How does this system work on the 3.2? Thanks |
| All times are GMT -8. The time now is 12:05 AM. |
