Sudden onset of oil smoke
I was driving my 3.2 Carrera hard at the track this weekend and mid-way through the second day started to get large clouds of oil smoke during decel.
Prior to that I hadn't seen any smoke.
Thought maybe it was oil into the breather pipe from hard cornering and hilly track but we couldn't see any traces of oil in there when we inspected it, and we hadn't added any. Level slightly above the bottom dipstick mark.
The engine has about 15K on a complete top end rebuild including rings. It smoked some before the rebuild but never like it does now....and I had some pretty worn exhaust valve guides.
Through the remaining sessions it continued to smoke but seemed to subside a little bit. No smoke at idle or on hard acceleration.
Any suggestions about how to diagnose this, besides the usual compression check and leakdown tests?
Old 11-09-2010, 08:13 PM
E Sully's Avatar
You could remove the exhaust and look at the exhaust valves and guides.
Ed
1973.5 T
Old 11-10-2010, 03:53 AM
Make Bruins Great Again
Por_sha911's Avatar
Assuming no overheating or over-revs, a bad valve guide? Does it make any new noises?
Joe
Old 11-10-2010, 02:44 PM
No new noises....and seems to run strong
I can't believe guides could wear out in less than 15K. I'm hoping there's another cause.
Old 11-11-2010, 05:44 PM
brads911sc's Avatar
How is your compression and leak down numbers?
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 11-11-2010, 07:45 PM
Examined spark plugs and found 5 grey/brown ones and number 6 very black. Didn't seem like oil fouling (i've had that).
Replaced the injector and problem solved.
Runs much smoother and no smoke!
Old 12-06-2010, 06:16 PM
kodioneill's Avatar
Well done!! good diagnosis and repair.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-07-2010, 06:08 AM
