Oil Change for '89 Targa
Question - first time owner and looking for general maintenance to be done after a winter in the garage. I have an 89 911 Targa (non turbo) with 114K on it. Is Jiffy Lube suffice or do I need to go somewhere special? Any other general maintenance you recommend for this many miles?
Old 05-08-2010, 05:11 PM
GrantG's Avatar
Do not go to Jiffy Lube! This is easily done yourself, but if you'd rather not, go to an independent service station that works with aircooled Porsches or get a buddy to do it for you (takes only 20 minutes, but lots of oil, a proper Mahle filter and a couple crush rings).
Pelican has a DIY in the Technical Articles.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 05-08-2010, 05:23 PM
Northern Motorhead
wildcat077's Avatar
Oil changes are best done by the owner of the car,that being you !
Read up on the procedure,get yourself a very large pail... i use an empty chlorine puck bucket from my pool for draining the tank and one of those flat regular oil trays for the engine.
Pelican sells the Mahle filters and as far as the oil to use,i use Mobil 1 15w50 in my 89 and i'm very satisfied with it.There are endless oil threads and you will get dizzy before you finish reading up on them ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-08-2010, 06:25 PM
rnln's Avatar
after being my cars to several places and watching them doing it, I decided either do it myself, or only the "air cool 911 mechanics" do it only.
Fat butt 911, 1987
Old 05-08-2010, 10:35 PM
Wilhelm's Avatar
NEVER take it to Jiffy Lube or any of that sort of place for ANYTHING! I wouldn't even take my Ford to them. As stated in a previous post, it is not a difficult job to do an oil/filter change on a 911. Just have a BIG drain pan.
Old 05-08-2010, 10:50 PM
eauboy's Avatar
I would wager that at Jiffy Lube you would get the engine case drained, they would miss the oil tank, and would then overfill it.
Made the mistake of taking my Acura MDX there for an oil change winter before last when it was seriously cold one weekend and ended up with stripped threads on the oil pan.
Lesson learned.
'85 Carrera Iris Blue Metallic Coupe
Old 05-09-2010, 01:32 AM
redranger's Avatar
I'd be most worried about one of these places jacking up the car in the wrong place and either crushing an oil line or damaging the underbody. These cars can be tricky to jack up if you aren't familiar with them. Changing the oil in this car is very easy, no jack is required. Trickiest part is the filter given the risk that oil can get all over the engine bay if you aren't careful.
86 Targa
Old 05-09-2010, 04:01 AM
GrantG's Avatar
At places like Jiffy Lube, I think you drive your car over a pit and it's never jacked up (I haven't been to one in many years), so that risk is not a serious as the others mentioned.
Old 05-09-2010, 06:04 AM
kodioneill's Avatar
Would you take your RS there for an oil change ?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 05-09-2010, 06:29 AM
Northern Motorhead
wildcat077's Avatar
I don't see myself running my car with Jiffy oil ... lol
Cheers
Phil
Old 05-09-2010, 07:00 AM
GrantG's Avatar
No, I like changing my own oil.
Old 05-09-2010, 07:10 AM
Paul K's Avatar
How to change the oil on an '89 targa...
http://forums.pelicanparts.com/porsche-911-technical-forum/374532-first-oil-change-success.html
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 05-09-2010, 07:20 AM
initial's Avatar
Jiffy lube is not that scary.. I do my own oil changes which are quite easy, but when it came time to change the tranny oil, I felt is was easier and quicker to go a Jiffy Lube..
I just drove over the pit, handed them the oil I had prepurchased, gave them a few simple directions (where the plugs are, how much oil should go in, filing till it comes out the top plug, etc..) and the job was done in no time at a very low cost..
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 05-09-2010, 07:36 AM
