Which brand/grade fluids do you use for your daily driver 911?
Which engine oil brand and grade?
Which oil filter? Which tranny fluid? Which brake fluid and pads? Lot of talk about Brad Penn, Super Blue ATE, etc but aren't they overkill for a daily driver? My car is a non-track 911 that gets driven only 5000 miles per year. No autocrossing or rallying. It is actually driven by my wife almost 100% of the time to/from work in 50 degree weather in the winter and 110 degree heat of the summer. If your car is a daily driver only, which brand of fluids,etc do you use? |
I use the best stuff out there. Some daily drives can be just as hard as track events on the engine and brakes. And, i'm worth it! Beside, there is good stuff (brad penn, swepco, ate, oem) and there is everything else you find at pepboys. Cost isn't that much more for piece of mind.
James Brown - doesn't the factory/dealer use the same stuff you buy at PepBoys?
Swepco 306 14W40
OEM Porsche oil filter Swepco 201 Ate brake fluid OEM Porsche pads You didn't ask but I use Shell gas, no ethanol JR |
Shell Rotella T 15w40 (10w40 winter months below 20 deg. F( 5 of them this past year))
WIX filter swepco 201 whatever brake fluid the shop that did my master cyl used. oem pads 91 octane gas wherever i can find it, and more often than not without ethanol(hard in Western NE) |
Mobil 10W40
Miller transmission fluid 80W90 Miller 300 plus OEM pads Normal Euro 98 octane super sometimes shell Vpower |
Porsche or Mahle filter Swepco 201 though will try Kendall LSD next change - 10K on my road cars Motul 600 with Porsche pads - Fluid bled/semi-flushed with fresh yearly |
Exactly Ruby.
I use Mahle OC54 filter on oil filter. Napa Gold is also excellent and the same price. In fact many say its better. I still use Mahle because I bought 4 of them the last time. ATE Blue brake fluid. Kendall Gear Oil. Kendall GT1 or Valvoline VR1 motor oil. I can get it all locally with no shipping or hassle except the oil filter which I bought as a lot of 4 off fleabay. Our host also sells it with no hassle. I think if you can get VR1 at your local autozone or GT1 at your local distributor.. both at $4 a quart... then buying Castrol, or some questionable oil for $3.50 a quart doesnt really make alot of sense. right? Quote:
Brake fluid and pads.....not so important for a street car.
Just keep the fluid fresh. I would use the "correct" tranny fluid so that your synchros and LSD (if you have one) are properly lubed. Factory oil filters are the best and not that much coin. Finally, and most importantly, you should re-read the long post on Brad Penn motor oil. If that doesn't prompt you to put that stuff in your engine, no matter what the car's intended use, nothing will. The engine is the single most expensive component on a 911. Really costly if something goes wrong. Guess I don't understand why some wish to save a few cents or cut corners in maintaining a 911. Just not worth it in the end. If I were buying your car.....I'd want to know if it had used Brad Penn regularly or some less expensive brand. It would make a difference to me on whether I wanted to buy your car or not. IMHO |
Kendall GT-1 20W/50 non-synthetic engine oil
OC 54 oil filter (Mahle) Kendall dino 80W/90 GL-5 NS-MP gear oil Castrol LMA brake fluid (used to use Ate Blue for track) Jurid/Pagid/BHP brake pads depending on what I'm testing (used to use Porterfield or Pagid competition for track) - BHP pads on car now, slightly noisy but I like them. |
Mann or Mahle Filter, Vavoline 10 w 40 Vavoline Brake Fluid (Blue used to be Silver container), Carbon Metalic Brake Pads (Performance Friction now called PFC) The only thing new I am trying is Lucas Oil in the Trans/Axle. I was using Mobil 1, but the 915 trans did not like it! When I am not using a full Molly grease I use Mobil 1 syn grease.
I Never use Shell Gasoline! Short story was my 1976 would stop running and then after checking everything it would fire up and we drive away. After changing fuel Pumps adding extra 1 way valves, a 924 Accumulator, Mounting Fuel Pressure guages in the engine compartment, one day someone said, What kind of Gasoline do you use? He then stated that he had "Heard Things" about using Shell. I started to use Texaco and others and all of a sudden all of the problems went away. My thinking is the arromatics and additives they add to the fuel made it Vaporize faster and in the Hot engine compartment I would get Vapor Lock. |
I don't know what the PO of my car used for the gear oil, but I just ordered some Kendall NS-MP and plan to switch it out soon.
As for the other stuff, I use VR1 non-synthetic 20w50 (as of yesterday, got it from AutoZone), Mahle OC54 (from Pelican), and Motul brake fluid. |
Ruby, not sure what Porsche dealers use now but I would not be surprised if they use the lowest bidder for consumables. It's a cost thing.
My Dad would never, ever use Shell. He said it didn't mix well with other gasolines.
This was in the 60s... |
There's at least one thread out there that goes into some depth explaining why you should no longer use the factory oil filter. Mahle for me.
Mahle oil filter. The Porsche factory is selling some sort of crap oil filter; do not buy it.
Chevron gas is the best. I can't say much though because I usually fill up if I drive by a Costco with a half tank empty, and I've been known to gas up in some out of the way places. Valvoline VR1 Racing 20-50. No matter what type of gas you use, run a tank of gas with Techron or equivalent before each oil change. I have become a fan of PBR/Centric/Pagid ULT or Ultimate Ceramic pads. They have huge initial bite and low brake fade. They work well with the factory rotors. Swepco 201 |
Doug, I prefer a car that is NOT running Brad Penn. Just my .02. Yes, I have read all the threads. Pleanty of other better oils like Swepco 306, VR1 or GT1. Good luck.
Brad Quote:
Engine: Brad Penn 20W-50
Oil filter: Mahle OC 54 Transaxle: Kendall NS-MP 80W-90 Brake fluid: Castrol LMA (or ATE Gold) Brake pads: Textar Gasoline: Shell V-power (I don't have Chevron near me, and Shell at least qualifies as a top tier gasoline: http://www.toptiergas.com/). In any event, I am a fan of periodic use of Techron concentrate. BTW, Chevron has a free iPhone app to help locate the nearest station. Helped confirm for me that I'm SOL in CO.... |
| All times are GMT -8. The time now is 10:20 PM. |
