rusnak |
09-20-2010 01:26 PM |
Originally Posted by lettera32
(Post 5570238)
But what about no high beam. Switch, or wiring?
If you find that you have no high beam, or no low beam, try using some snap ring pliers to spin the retaining collar for the light switch, then pull the light switch out backwards, and retract it out of the dash. Letting it hang down, you can inspect the electrical contacts. You should check and clean the spade connectors, which are probably either loose, dirty, or both. It's a quick 5 minute fix.
