-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Voltage Regulator Question ( Please Help) (http://forums.pelicanparts.com/showthread.php?t=564879)
ppanagis@gmail. 09-17-2010 06:49 AM
Car 911t 1973.5 2.4
Alternator Marchal
So a few weeks ago my battery died on me. I figured that the alternator was not charging. I had the alternator checked and turns out that it's fine. So I verified that the ground on the transmission was securely attached. Checked the cables on the selenoid starter. Also repainted my fan housing and made sure that all the grounds were clear of painted and tested the ground. The RED Alternator light is constantly on.
BTW Had the battery tested it was good...
I went out to my local parts store and they sold me a bosch VR. Installed it. Nothing... Red light solid
So I called pelican and was surprised to find out that I apparently had the wrong voltage regulator to begin with. Unfortunately pelican does not have these regulators anymore. Luckily i got my hands on one and it is being shipped.
My question is can it be something else than a regulator. I heard a loud clicking behind the dash when it first died and i would figure that when i put the bosch unit even if it's not the right regulator it would at least do something.http://forums.pelicanparts.com/uploa...1284731328.jpg
ppanagis@gmail. 09-18-2010 07:55 AM
bump
rwest 09-18-2010 09:15 AM
Hello,
Have you checked the voltage at the battery when the car is running? It should be near 14 volts if everything is working right. Also, I once had a rebuilt alternator that tested fine on a bench, but turned out to be defective. I probably wasn't real helpful, but I wish you luck, and hope some of the more knowledgeable guys can help out.
john walker's workshop 09-18-2010 09:22 AM
once in a while i find that the alternator was changed to a internal regulator style in the past, and the old regulator was still plugged in.
tcar 09-18-2010 09:22 AM
If your alternator was replaced in the last 5-10 years, it could (probably) has an internal VR - part of the alternator.
They stopped using the external VR in 81 or so. The old one was on the L (driver's) side of the engine compartment by the relays.
Mine is still there on my 78, but it's disconnected. I have a newer alternator.
You might check to see if you even need the external regulator. Or if you have an internal regulator that is bad.
ppanagis@gmail. 09-19-2010 08:10 AM
Ok I checked with John at Pelican ... I have an early style Marchal alternator which definitely requires and external Voltage regulator. Also voltage test on the battery... once the battery is charged the voltage does not change at any rev...
Seems like the VR is the issue but why did it not do anything when I put the bosch unit?
should I be looking at relays fuses etc...
john walker's workshop 09-19-2010 08:49 AM
the red charging light in your dash gauge needs to work with the ignition switch in the ON position. does it? 12V goes through it and grounds through the D+/61 terminal on the alternator. the blue wire. dead bulb=no charging. worn brushes can also interrupt that circuit if they don't touch the commutator.
ppanagis@gmail. 09-20-2010 07:13 PM
Hey John,
Sorry iI blew my Tester and needed to go buy another before i responded.
Red light is on .... I tested the red wirer to the ground and got 12 volts BUT that is only because my battery is charged.
so are we still thinking its the regulator?
47silver 09-20-2010 09:18 PM
get an adjustable vr
i had the same problem,, the fixed vr's sometimes charge too low. The guy i have do myb alternators, told me to try an adjustable one.
i set it to 14v, all is fine now, that was in the spring.
Glen Pettigrew 09-20-2010 09:54 PM
Per Tech article "Alternator System Troubleshooting" under 914 on this site.
unplug the three wires on voltage regulator (if individual wires, note where
they were plugged in. Jumper wires D+/61 (blue) and DF (black) together.
Start car and measure voltage at battery. If voltage is near 14v, alternator
is good, voltage regulator is most likely bad. If voltage is still 12v, alternator
is most likely bad and voltage regulator condition is unknown at this time.
This is assuming all of your wiring is correct.
Glen Pettigrew
Edit: Do not let the engine run very long in the jumpered condition.
It will over charge you battery!
ppanagis@gmail. 09-21-2010 06:39 PM
Ok so i jumped the cables as described above...Nothin... no change in voltage what so ever. Went back to the shop that the alternator was tested and they said that the alternator is good.
Something you should know. This is a 912 that was converted to a 911t. the wiring may not be spec.
- Red wire from B+ going to a live wire from the battery
- Brown wire coming from the alternator D- to a grown on the frame. there was a connecting wire going to the VR.
- black wire going from the DF on the Alternator to the DF on the old VR
- Another black wire going from D+ to the VR- this wirer is connected to a blue wire that activates the red light on the dash.
SO before i even start trying to connect the VR i should be getting something from the alternator. I'm at a total loss... Please help:(
http://forums.pelicanparts.com/uploa...1285119447.jpg
john walker's workshop 09-21-2010 06:46 PM
Originally Posted by ppanagis@gmail. (Post 5572365)
Hey John,
on with the key in the ON position and goes out when the engine starts?
ppanagis@gmail. 09-21-2010 06:48 PM
sorry John if you mean the red light goes off.... No it does not
ppanagis@gmail. 09-21-2010 07:00 PM
going back to m original problem..."I heard a loud clicking behind the dash when it first died "
Can this have anything to do with it?
Glen Pettigrew 09-21-2010 07:53 PM
So you jumpered the two wires highlighted in Red below?
And still only had 12v at the battery with the engine running at
or above 2000 rpm?
ppanagis@gmail. 09-21-2010 08:34 PM
Correct
ppanagis@gmail. 09-21-2010 09:03 PM
Small illustration to make sure i'm wired correctly....http://forums.pelicanparts.com/uploa...1285128173.jpg
47silver 09-21-2010 09:19 PM
wiring seems ok
see this drawing for the wiring. yours looks ok... I posted above that you may need an adjustable voltage regulator as the stock one does not charge high enough so you batter goes dead.
If your alternator is ok it is your wiring or voltage regulator.
wire it up as shown on the attached (you can find the legend on this site) item 3 and 4 are the alternator and voltage regulator..
http://forums.pelicanparts.com/uploa...1285129179.jpg
Glen Pettigrew 09-22-2010 03:20 AM
Originally Posted by ppanagis@gmail. (Post 5574472)
Correct
or above 2000 rpm?
Ok;
1. With D- grounded to frame ground.
2. B+ connectect to battery.
3. D+/61 connected to DF via jumper.
4. Negative of Battery connected to frame ground.
5. engine running at or above 2000rpm.
6. still 12v only at battery.
= Alternator is BAD!
This test has isolated everything between the
alternator and the car, other than battery, frame ground
and Large Red wire between alternator and battery
Glen Pettigrew
ppanagis@gmail. 09-24-2010 01:09 PM
OK I spend 3 hours with a Frank from Volta ( company that repairs rebuilds alternators)
Here is the problem. The Voltage regulator needs to be "jolted"as frank put it? in order for it to start working... what this means is that some alternators have a feature that upon start up a surge in power actually wakes up the VR into starting. The Voltage regulator can sometimes have this feature also but the one i purchased doesn't have it Frank also suspected that i may have difficulty finding one that does.
SO what we did is put the alternator on a testing machine and connected the VR. what we found was that the alternator was working well and that the VR was not working. He then put a positive connection on the VR's connection FLD. BAM it worked like a charm. So we then connected a wire with a resistor that is used in other alternators for that same purpose directly between the positive. There was leakage approximately 74 amps, meaning it would drain my battery after several days.
So this is the part where you guy's may not agree with the solution and even i am hesitant but i have no choice since this is the second regulator and I'm out of options. I will interrupt the connection and turn it on for one second after initial start up. Below is a diagram of what it looks like. the new wiring is indicated as green. Appreciate your comments or better ideas!
ppanagis@gmail. 09-24-2010 01:11 PM
http://forums.pelicanparts.com/uploa...1285359062.jpg
47silver 09-24-2010 01:18 PM
resistor
you need the resistor that goes on your alternator light in the dash,, do a search here for the size and capacity 5k ohm i think..
it goes across the light and excites the alternator.
ppanagis@gmail. 09-24-2010 01:19 PM
sorry your correct... The dash light is connected at the IGN... i forgot to illustrate that. Is that what your refering too?
304065 09-24-2010 02:14 PM
STOP
If you want to kill the alternator it's better to take it out and hit it with a sledgehammer! :)
DF= black wire from VR to DF terminal on the alternator. This is the "Dynamo Field" wire, it sends voltage from the VR directly to the alternator field.
D+/61, this is the "blue wire circuit."
The "blue wire" circuit is like this
Battery----> ignition switch -----> bulb holder for warning light in oil pressure gauge ----> blue wire to electrical console ---> voltage regulator ----> D+/61 terminal on alternator.
In your diagram above, REMOVE the green wires! And connect a blue wire between the IGN terminal of the Voltage Regulator and the bulb holder in the dash. Other terminal of the bulb holder goes to +12v from the ignition switch.
D- ground ok
B+ battery positive OK.
Search here for "blue wire" for a couple dozen threads that explain how this work.
Not trying to scare you, but the way you have it set up, you are basically going to burn up the alternator in a very short time.
Good luck!
ppanagis@gmail. 09-24-2010 02:27 PM
Just to be clear the colors do not reflect the actual colors of my connections. The wires are not original color.
Currently this is how the black wirer on the diagram is plugged in...
ppanagis@gmail. 09-24-2010 02:28 PM
If i understand you correctly i am connected the way you discribed. The green wire is a mitigation to my issue discribed above with the VR and it's need to be jolted to start working.
DO you still think i will blow my alternator???
http://forums.pelicanparts.com/uploa...1285363680.jpg
47silver 09-24-2010 09:30 PM
resistor across the dash light
you need a resistor across your dash light please review this post.
http://forums.pelicanparts.com/porsche-911-technical-forum/454898-just-replaced-alternator-now-i-have-battery-light-warning.html
ppanagis@gmail. 09-26-2010 06:43 PM
Very wierd
So i finally fixed my issue and did not need to wirer the car differently. What is weird is that the voltage regulator is now charging the battery and all it needed was a boost. What i did was installed the regulator like i mentioned above and it did not work. I connected the green wirer with the resister between the FLD and the + feed for one second and it worked. The weird thing is i turned off the car expecting it to need another jolt but it works fine.
I'm not sure what is the fix here but maybe this can help someone with a voltage regulator issue similar to mine...
doug-ocon 10-26-2010 03:44 PM
I was following your thread and the last Post references "Below is a diagram" but nothing is attached. i am having the exact same issue putting a 911 engine ion a 912 and i don't want to cross wire the regulator. Will you reply with your diagram or repost? thanks for your time
Doug O'Connor
doug-ocon 10-26-2010 03:52 PM
never mind ... I failed to turn the page
ppanagis@gmail. 10-26-2010 04:46 PM
No worries..would love to see pictures of your car sometime
