Banned
checking for sparks at the cylinders
What's the best way to quickly check for sparks at the cylinders ?
Unplugging a socket and getting it close to an intake runner, for instance ? |
Pull the plug wire off a spark plug, plug a spare spark plug into it, hold the plug tip against the engine to ground it, crank the engine, and look for spark at the spare spark plug tip.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Senior Member
Today's ignition systems pack a punch. Ignition systems used to be 15,000 volts. Today, 30,000 volts is weak. If you've ever experienced becoming a conductor in one of these systems, it makes you very cautious. DO NOT pull a spark plug wire off the spark plug on a running engine. Those volts will look for a path to ground. A better method is to pull the wire off the top of the distributor cap. The spark will jump from the cap to the wire, as you separate them. You can see and hear it. Use insulated pliers if you can, but this can usually be done with bare hands without trouble. Usually. On the other hand, conventional wisdom is that you never put your hand anywhere near the distributor of a running engine.
If you have the time, David's method is good. Actually, if you have a timing light, put it on each of the ignition wires. If it flashes, there is a spark happening.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Banned
That's good ! I have a timing light.
IMHO, this is the best way to assess spark continuity as well as quality (you want a nice fat blue one).
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Senior Member
Agreed. A nice, fat, blue, snappy spark. But you know.....weak sparks tend to fail when under the pressure of a cylinder. I've seen situations where the timing light flashes when hooked to a spark plug that is lying atop the head, but doesn't flash when connected to the spark plug screwed into the cylinder. The pressure in the cylinder makes the spark more challenging, apparently. If you pull a wire from the top of the distributor and it arcs a full inch or so to jump the gap between the distributor cap terminal and the wire, while the engine is running, without missing, then you can have confidence in the spark. You can also tell whether that cylinder is running well. When the wire is held too far away, the engine should run more poorly. But again.......touching the distributor of a running motor can be VERY exciting. Some might say "electrifying."
especially with MSD.
I use a spare spark plug - quick and easy on the road.
What you should never do is remove a spark plug from the engine and use it instead. Two issues here. First, you un-necessarily stress the thread and second you might get a mighty bang when the combustible gas coming out of the open cylinder ignites......
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
i use this from hf97577
this plugs into the wire, and to the spark plug so you can tell if it is getting a good ground etc..
10 bucks.
1975 911S Targa Silver Anniversary Edition |
Banned
im not HOLDING any plug wire while the engine is running. im certainly not pulling one out of a dist cap. ive been knocked on my butt before from a 911, and not because i was holding it. i did even hold my lawn mower plug wire the other day when it would not start.
do not use wire to coil
if you have an msd or cdi do not use the wire to the coil. It is high voltage not 12.
use one of the red wires under the fuse cover.
Disconnect any spark plug wire from a convenient spark plug. Insert longish Phillips screwdriver or equivalent into the connector, then position the exposed SD blade about 1/2 from a metal ground. Crank engine and observe the spark. Cost: Free.
Do not hold spark plug cable while engine is cranking or running unless you're prepared for a potential 6,000+ volt shock. If you want to be sorta high tech, purchase a plastic pair of pliers (just one) from an auto tool store. Sherwood |
