mspirito's Avatar
torque settings for A ARM bolts
Just finished the R & R of the A arms and bushings.
What is the correct torque setting for the bolts that hold the A arms, the 17 and 19 mm bolts?
Old 01-16-2011, 05:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You will then need to insure the A arms move freely without binding, tighten the bolts, not too tight then install the struts, replace sway bar, replace the tires, lower your baby, let her settle then torque the bolts.
Be right back, checking Bentley..................
Front 35lbs (17MM)
Rear 66lbs (19MM)
'85 Carrera Targa
PCA/POC
Old 01-16-2011, 05:56 PM
French Import
zippy_gg's Avatar
Bentley says:
Control Arm to body Front Bracket (M10)47Nm (35 ft-lb)
Crossmember subframe (M12) 90 Nm (66 ft-lb)
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-16-2011, 06:08 PM
mspirito's Avatar
thanks
Thanks for the help
Old 01-16-2011, 06:09 PM
