Author of "101 Projects"
Wayne 962's Avatar
Back to work on the 959 tonight...
Had a rough day, so I decided to retreat to the garage to work on the 959. I'm replacing the discs, and the shocks, and still working on the hydraulic accumulators. I don't have much time to caption, but I can post a few pics...
-Wayne
Old 01-23-2011, 11:39 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Wayne, I love the fact that the car is not spotlessly clean.
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 01-24-2011, 12:18 AM
cycling has-been
bkreigsr's Avatar
what's up in #1? did you have to grind off a frozen bolt head to separate the caliper halves? Do you have to break open the calipers every time you replace the pads? (doubtful for a car built for endurance racing?)
consider yourself lucky that your garage was warm enough to work in without gor-tex mittens and three layers of windbreakers (NJ=6 deg) Bill K
Old 01-24-2011, 05:49 AM
totle's Avatar
Nice :-) first time I have seen pictures from under a 959.
Nice to see the suspension set-up etc.
Please post more pictures
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-24-2011, 06:02 AM
Bill Verburg's Avatar
Did the 959 use 903 size rotors? 304x232 and 309x28 or something bigger? 23.8mm m/c?
Bill Verburg
Old 01-24-2011, 06:34 AM
Is that the handbrake caliper w/ the broken bolt?
Bill Verburg
Old 01-24-2011, 06:35 AM
cycling has-been
bkreigsr's Avatar
now I see it, said the blind man!! thanks Bill
Old 01-24-2011, 07:53 AM
jetstar911's Avatar
I love the "real world" pics! Not an everyday sight. Thanks for the pics. Would love to see more!
Old 01-24-2011, 02:38 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Looks like a broken guide pin/bolt on the handbrake caliper. Do you even need to remove those pins? It's a single piston sliding caliper that could come off with the ear mounts vs. "splitting" the caliper.
Kevin L
'86 Carrera "Larry"
Old 01-24-2011, 03:12 PM
Senior Advisor
James Brown's Avatar
Looks like the wheel well of a 737! Thats a lot of stuff in there. I would hate to run over a cat at high speed, might make a mess.
08 Cayenne Turbo
Old 01-24-2011, 03:15 PM
wayner's Avatar
Originally Posted by Wayne at Pelican Parts View Post
Had a rough day, so I decided to retreat to the garage to work on the 959. ...
Is that the laboratory of some mad scientist?
Old 01-24-2011, 03:28 PM
304065's Avatar
It's the backdrop for Wayne's new book 11 Projects for your 959
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-24-2011, 04:13 PM
1980 911 SC
Can't be factory. It's to easily accessible.
Life's a Beach
Old 01-24-2011, 04:47 PM
Every rough day is made better by retreating to the garage to work on the ol' 959-er. I guess.
Old 01-24-2011, 06:39 PM
Are those accumulators similar to the ones on my '88 BMW 535i used for brake boost, IIRC?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-24-2011, 06:47 PM
83 SC
CraigT's Avatar
wayne,
do you have more postings for the 959, i would really like to see more.
Old 01-24-2011, 07:27 PM
Wayne 962's Avatar
That's the handbrake caliper, and yes, you need to split it in order to get the rotor off. Normally, a pretty straightforward job, except for when the cap screw rounds off. I found that these bolts seemed unusually soft - this one was very easy to cut through.
-Wayne
Old 01-25-2011, 12:11 AM
Wayne 962's Avatar
Coming soon. Some more coffee, and then the install of the new rotors.
-Wayne
Old 01-25-2011, 12:12 AM
Wayne 962's Avatar
I could get the pads out, but I just didn't have enough room to get the disc off. The other side came off in less time than it took me to write this sentence!
-Wayne
Old 01-25-2011, 12:14 AM
Wayne 962's Avatar
It's mostly covered up in there - I have the covers off to work on it...
-Wayne
