1980 Porsche big brake kit question
Converting a newer big brake kit off a newer Porsche to an older car what kind kind of conversion kit is best my car is a 1980 wide body 911 non turbo Porsche with 18 in rims
Old 03-06-2012, 10:28 AM
Bill Verburg's Avatar
There is no one best for everyone, because everyone has different needs and restrictions and budget.
Generally the easiest bb install will be a '78-89 930 setup as the only machining necessary is for the rear calipers and no adapters are used at all. Dissadavantage is weight, cost, old design
993 and 993RS are nice bb but are overkill for most purposes, I put 993RS on my car more for looks than anything else, you need to modify the rear calipers and rear rotors and use a caliper adapter at both ends, Race Technology used to sell a bolt on kit which afaik is nla. disadvantages are weight, cost
996/997 turbo and Gt3 can be also be adapted these are even more powerful and heavy than 993RS, Instant-G dells these kits. disadvantages are weight, cost & bias issues
there are others such as Boxster which are really not an upgrade but if you like the looks they are available from a # of sources
Bill Verburg
Old 03-06-2012, 03:09 PM
Thank you very much I reached out to Instant G and they were helpful.
Bruce
Old 03-06-2012, 05:28 PM
