jager911 |
01-16-2014 06:26 PM |
Originally Posted by Flat6pac
(Post 5842647)
I would either wire the 10mm bolts together and use the 4 bolts or drill out the CV to install the extra 2 10mm bolts.
The better option would be find 2 good used sealed half shafts that go all the way to the stub axel from the 85 to 89 and install them complete. Remember you need the nut and washer for the outboard to match the half shaft stub axel
Bruce
Resurrecting Tom's thread as I started another similar thread tonight before seeing this one.
So, if I buy '85-'89 axles, is it a bolt-on solution to install a LSD from '86 915 (Euro) into my US '75 915 tranny? When I changed wheel bearings, it was a b*tch to break those nuts loose.
