Tim Boyer's Avatar
oil pump recognition by the # of fins??
HI,
I read somewhere that you can determine the year (s) of an oil pump by the number of fins that are found on its side. I am pretty sure that one with four fins is considered to be the desirable one. Can anyone confirm this or have a picture of a desirable oil pump for me to see so that I can confirm taht the oil pump that I have is the "better" one??
Thanks,
Tim
Old 02-13-2011, 03:34 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That's correct. The later pumps with 4 fins are the ones typically desired. Here's some nice pics of the later hi-po pumps people like to use for hotrodded engines.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/548297-when-use-gt3-vs-930-pump.html
Wayne's engine rebuild book has a complete section on the oil pump's progression throughout the air cooled engine's lifespan. The early pumps are typically replaced with the later 4 rib or greater pumps
Kevin L
'86 Carrera "Larry"
Old 02-13-2011, 05:51 PM
Tim Boyer's Avatar
HI,
Thanks for information. Maybe it was Wayne's book where I first saw this. I will have to check that out tonight.
Tim
Old 02-14-2011, 04:21 PM
Tim
Here's some pics of the various oil pumps
From the top:
1. Early AL pump used up through '68
2. 3 rib Mg pump used from around '69 through '75
3. 4 rib Mg pump incorporated in '76 with the oil bypass mod in the case
4. SC 4 rib Al pump used on the 78-83.5 SC's same as the Mg 4 rib pump but more resistant to wear
5. 3.2 Carrera pump which is the same as the SC pump but with a built in strainer designed to work with the no sump crankcase used from late '83-'89
6. 964 pump which is longer and requires the short layshaft connector
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 02-16-2011, 02:21 AM
Grady Clay's Avatar
Tom,
Great discription.
Can you repeat this image with a plain background?
This is a classic. Thanks.
Here is a GT3CUP pump.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-16-2011, 05:00 AM
Grady...I wish I could but I snapped this a while back for my own reference and do not currently have all these pumps in stock.
I am not that great with PhotoShop but anyone who wants to attempt a plain background is welcome to contact me for the original pic.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 02-16-2011, 08:15 AM
arrivederci's Avatar
I assume that #3 and #4 in the list are actually #3 in the picture (ie, look the same?). 6 listed, 5 pictured...
- '72 911T
- '81 911SC Euro
Old 02-16-2011, 12:26 PM
bavaria911's Avatar
I sure hope I have the right oil pump in my new 2.4S motor:
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 02-18-2011, 06:48 PM
Scott
Looks like 4 rib Al SC type pump...That's a good one for your case assuming you had the oil by-pass mod done.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 02-19-2011, 04:37 AM
Tim Boyer's Avatar
Thank you!
Thanks to all for their input, especially Tom. As always, he is one of the go to guys when it comes to information about Porsche's.
Tim
Old 02-19-2011, 05:56 AM
Here is a more complete description of the various oil pumps with pics
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 02-23-2011, 06:20 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Great image & thanks for sharing Tom. Note that the 83.5-89 930 pump part no. is incorrect. It should be 930-107-008-04. The part number shown is actually a 996 Turbo pump part no.
Kevin L
'86 Carrera "Larry"
Old 02-23-2011, 07:08 AM
Kevin
I think you are correct. The Turbo pump is NLA and the original P/N you mentioned has been superseded to the 996 P/N.
I'll make the correction to my chart.
Tom Butler
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 02-23-2011, 10:53 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I figured it was superseded (was going by parts diagrams), since you know your parts, and you are correct- plug in the original 930 pump P/N to Pelican catalog search and it supersedes to the 996TT pump. Good to know there's a newer replacement for worn out original 930 pumps.
Thanks,
Kevin
Kevin L
'86 Carrera "Larry"
Old 02-23-2011, 11:57 AM
Tim Boyer's Avatar
Tom,
Thanks for an even greater explaination of the various oil pumps, however, I have a question. Are these interchangable? If I wanted to use a 4 rib pump in a earlier 70's motor, could I do it? If so, are they all interchangable or only certain ones?
Thanks,
Tim
Old 02-23-2011, 03:08 PM
Max Sluiter
Flieger's Avatar
Longer ones need shorter drive shafts. Larger ones need to have a bit of case webbing machined for clearance.
Old 02-23-2011, 04:26 PM
Originally Posted by Tim Boyer View Post
Tom,
Thanks,
Tim
Tim
The 4 rib pumps work best when the oil bypass mod has been done on the case. The Carrera, 964 and Turbo pumps require that you use a dished sump plate on an early case to clear the strainer.
The 964 and Turbo pumps use a shorter connector shaft.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 02-23-2011, 06:27 PM
Tags
oil pump
