Where to tap into 12 volts?
Where is a good spot in the engine compartment to draw power - 12 volts switched through the ignition? I am putting on an Autothority MAF (among other things), but I don't really want to cut into the ICV harness to tap into the power.
Any recommendations? Thanks,
Mike
Old 03-28-2011, 09:37 AM
RETIRED
Joe Bob's Avatar
On the left side of the engine bay there is a fuse panel under the black plastic cover. There are a few switched power fuses. Depending on your car's options they may be unused.
2012 ML350 3.0 Turbo Diesel
Old 03-28-2011, 09:46 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yep. I agree with JB. That fuse panel is switched. I have a mini hourmeter in the engine bay that is powered from that panel.
Kevin L
'86 Carrera "Larry"
Old 03-28-2011, 10:15 AM
RETIRED
Joe Bob's Avatar
NOT ALL are switched. Verify with a meter or test lamp. Use an appropriate fuse.
Old 03-28-2011, 10:17 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Yes, I should clarify. Some are switched, some are hot/12V constant. A recent thread on fuel filter replacement reminded me of that.
Kevin L
'86 Carrera "Larry"
Old 03-28-2011, 10:20 AM
Alright. Thanks guys.
Old 03-28-2011, 10:36 AM
