-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   PCV 3.2 Does she need it or TEMINATE? How? (http://forums.pelicanparts.com/showthread.php?t=614095)
DRACO A5OG 06-14-2011 10:20 PM
Hey Fellas,
How many of you have Capped Off or Terminated the PCV. Pics Please ???
Today my wrench told me if it fails it will mess with the idle, creating a vacuum leak of sorts.
What are your experiences?
Can it be cleaned?
PCV & Rubber Sleeve "baffle" are NLA PAG or PPB so that sucks :eek:
Compliment of GH85Carrera:
http://forums.pelicanparts.com/uploa...1293134614.jpg
TIA
DRACO A5OG 06-14-2011 10:27 PM
Oh Crap, FLAPS has it for $9.99 :eek:
http://contentinfo.autozone.com/znet.../4298/image/2/
and the Baffle, I can't believe it:
http://contentinfo.autozone.com/znet.../5333/image/2/
Flat Six 06-15-2011 09:45 AM
Hey DRACO, you have a part number / source for the PCV valve?
TIA
Dale
DRACO A5OG 06-15-2011 10:07 AM
PCV AZ# 4298 $9.99
Baffle AZ#5333 $9.99
Special Order to home or store.
Flat Six 06-15-2011 10:34 AM
Originally Posted by DRACO A5OG (Post 6081084)
PCV AZ# 4298 $9.99
Appreciate it, bro -- thanks.
DRACO A5OG 06-15-2011 11:29 AM
Just order mine at store in 2 days :D
GH85Carrera 06-15-2011 12:01 PM
Hey that photo looks familiar! :)
DRACO A5OG 06-15-2011 12:02 PM
Hey Glen, hope you don't mind?
BTW, what did you do with your PCV???
Jim
DRACO A5OG 06-16-2011 08:56 PM
Update: The Baffles will not work, but the PCV looks proper, will install and report
DRACO A5OG 07-27-2011 09:29 PM
Installed, no change.
Next Fuel Pressure Regulator (FPR)
Quicksilver 07-28-2011 05:45 AM
As a rule removing a PVC valve by blocking it off will cause an engine to build up pressure in the crankcase causing it to leak oil like crazy. The layout of the oil system of the 911 motor is a fair bit different from the average wetsump system but I can't see how it could avoid the same problem. If there was any openings that could release the crankcase pressure those openings would also allow dirt into the system.
So either you must have a PVC (which you have found for cheap) or you must have a breather (which would fail emissions).
Jonny042 07-28-2011 07:08 AM
I may be wrong, but thermo swtich on the TB opens the path to that hose only during cold weather.
The two large hoses provide all the pressure relief you need, and the vapors are fed into the intake. The entire crankcase/oil tank is under "semi" vacuum, the vacuum that exists after the AFM, but not full intake vacuum that exists after the throttle plate.
FWIW, mine is blocked off. No ill effects.
E Sully 07-28-2011 10:08 AM
It's to prevent icing on the throttle body in cold temps.
I just capped it off on my 3.2, but I don't drive it in cold weather.
http://forums.pelicanparts.com/uploa...1311872898.jpg
DRACO A5OG 07-28-2011 10:14 AM
Do you have a pic of the cap off? SoCal has no icing issues :D
big911fan 07-28-2011 02:27 PM
Hose Clamps
I don't want to intrude on this post put the picture of the PCV with the hose clamps got me wondering. I've never tried to remove that type of hose clamp. Is there a secret?
It looks like it takes a special crimper to replace with the exact type clamp. Do you just open it with a screw driver or something and replace it with a conventional hose clamp? Thanks.
DRACO A5OG 07-28-2011 02:42 PM
Oh No intrusion Brother.
Yes indeed it uses a special crimper or a Wire Nipper $12.00 at an Hardware store. BUt only to crimp on, it needs to be destroyed if removed to get it off. So I used the nipper to cut it off but used a Standard hose clamp to put the new PCV valve on around the OEM baffle.
1990C4S 07-28-2011 04:24 PM
Oetiker clamps. Easy to put on. Not easy to re-use.
Pliers are shown as 'manual closing tools' on this page:
Installation Tools Products Clamps and Rings OETIKER International
Buckeye 05-12-2013 01:29 PM
Thanks for the info I will call a dealer tomorrow.
Pasophisto 06-05-2013 12:07 PM
What is FLAPS?
I need those parts:
PCV AZ# 4298 $9.99
Where do I get them?
SMS
DRACO A5OG 06-05-2013 12:24 PM
FLAPS = friendly local auto parts store
Found it at zone de auto :-D
JAR0023 06-05-2013 12:25 PM
Originally Posted by Pasophisto (Post 7482695)
I need those parts:
PCV AZ# 4298 $9.99
SMS
I believe the AZ denotes that those are AutoZone part numbers. Actually, a quick check at AZdotcom confirms that they are indeed AZ par numbers. -J
aj88cab 06-05-2013 12:29 PM
AZ=Autozone:)
(and a little slow on the keyboard...)
Chuck.H 11-05-2013 06:16 AM
Just to re-open this thread, still looking for the rubber piece attached to the PCV.
Since the baffle part number indicated here does not seem to fit, does anybody have the correct part number for the rubber attached to the PCV valve (I realized that says valve twice, but it reads better).
I want to replace both on my upcoming engine out maintenance cycle.
If I can't find it I'll use John Walkers trick of covering it with heat shrink!
Chuck.H
'89 TurboLookTarga, 365k miles
john walker's workshop 11-05-2013 06:52 AM
you can "fix" the cracked rubber sleeve with a short piece of shrink tubing and a heat gun. it comes in all sizes. same for the one in the left upper area of the engine.
Pasophisto 04-26-2014 11:58 PM
ok old post but...
Lots of talk about oil or oil vapour getting sucked back into the intake and becoming smoke. We don't like smoke. Can I disconnect one or both of the crankcase breathers? What if the PCV hose and valve vent the crankcase and don't make it back to the intake?
I know it's not PC to vent to atmosphere without reburning, but I'm talking mechanical issues here. IF my car is sucking oil into the intake, I'll fix it by disconnecting what?
Sheldon
Snowboard888 11-17-2015 07:56 PM
Pcv rubber piece available at paragon parts for cheap
I couldnt find the part at flaps and have been looking all over, finally found it a paragon parts you have to call them as its not on the website.
DRACO A5OG 11-17-2015 09:59 PM
You can also order it online:
Spectre/PCV valve for breather 4284 - May not be legal for use on pollution controlled vehicles 4298 - Read 1 Reviews on Spectre #4298
Spectre/Valve cover grommet 5333 - Read Reviews on Spectre #5333
Ha, they lowered the price on the baffle :-P
OffCamber00 11-18-2015 09:55 AM
Sheldon
You need only the single crankcase breather to oil tank. Beyond that, I installed an oil tank breather catch can and removed all of the other hoses. I capped the inlets on the throttle body/rubber boot and I capped the corresponding intake and PVC outlets at the oil tank. No issues for last two years on my 3.2
KTL 11-18-2015 02:02 PM
3.2 swaps into older cars often eliminate the PCV system, because they forget to pirate it from the donor car. There are many of these cars running 3.2 Motronic engines with no ill effects. I agree the PCV installation on these cars is an unnecessary redundancy because the engine & oil tank have ample breathe-ability with the engine case breather feeding the oil tank, and the oil tank breather being plumbed right back into the throttle body rubber elbow.
NICE 69 S 11-18-2015 03:08 PM
Oetiker Clamps
Just in case any of you are interested in using the Oetiker Clamps, which are far superior to the screw on clamps, the installation tool can be found in most Home Depot stores in the Plumbing section for around $60. They also have a few different sized fittings, but you can find all the different sizes on-line.
Bob B
KTL 11-19-2015 11:24 AM
I agree with Bob that the Oetiker clamps are really nice. The single ear clamps with double banding are the real deal just like Porsche used back in the day. You can get the clamps at McMaster, as well as the pincer pliers he mentioned.
McMaster-Carr Oetiker Clamps
McMaster-Carr Oetiker crimp pliers
