greg79s
Bad 3.2 Oil line. Repair or Replace?
My tensioner oil line has developed a leak. Is this fitting repairable or does the whole line need to be replaced? Here is an Image.
Old 08-02-2011, 12:56 AM
Spiderman
Jesse16's Avatar
I had to replace one this spring on the passenger side after re-using the existing part after an engine out rebuild on my 87. Both "looked" really good and hadn't leaked. Thinking your best bet cost and otherwise is to replace it. All the little ferrules and moving bits could be a bit worn over time and if something else leaks on re-assy, you'll regret it. I was able to get to mine in place on that side. Not horrible expensive.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 08-02-2011, 05:39 AM
biggest tensioner oil line i've ever seen. i'd replace it, unless money is tight.
206 637 4071
Old 08-02-2011, 06:14 AM
dshepp806's Avatar
Yes: new=best (over the long haul) !!!!!!!!!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-02-2011, 02:54 PM
Still the biggest problem is that line is on the back side of the thermostat. Suggest you consider replacing both lines and cut the nuts off at the thermostat with a die grinder so you dont ruin the threads of the thermostat by using a bigger wrench.
Bruce
Old 08-02-2011, 04:00 PM
The starting point for fixing a(n) oil leak(s) is to clean everything so you can see where it's coming from.
Old 08-02-2011, 06:03 PM
greg79s
Thanks for all input. Will replace.
Old 08-07-2011, 09:58 PM
