Always learning
What's the easiest way to determine car weight?
Any thoughts?
Public weighbridge is probably the simplest basic raw measure. Local recycling centre where they weigh the trucks going in and again on the way out to determine the amount dumped. Difference going in and out is zero if you don't drop anything off, but they will tell you what you weigh if you ask.
Scrutineering bays at local track can also have scales - often you only have to ask. Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83 Keep buying parts to make it look older. Mid life crisis is now in its 12th year. Last edited by Mothy; 08-11-2011 at 03:52 AM.. |
I took my car to a place that sells stone. Just go in and ask if you can weigh the car, they won't mind.
O2 In Sully We Believe |
Air Medal or two
The Big Trk scales even if certified can be off a bit..you will have to use the law of averages
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Canyon Runner
Lbs
I took mine to the local dump, on a weekday.Scales are accurate.They're always cool & enjoy seeing & hearing the car
2400 lbs with 3/4 tank of gas . 204 HP
+1 for the dump
just look dumb, lost and confused...say you took a wrong turn and need to know how to get out of here....and OH BTW how much doen it say my car weighs
Ed M 86' Coupe |
