-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Rennshift Question, for those who have one (http://forums.pelicanparts.com/showthread.php?t=627956)
moneymanager 09-03-2011 12:37 PM
Can someone tell me where the rennshift lever is when the car is in neutral?
Is it positioned between 3rd and 4th so that you exert extra effort to move it into either 5th/reverse or 1st/2nd? Or does it fall into neutral so that the only extra effort required is to go to 5th/reverse? I'm trying to compare the "feel" of the Rennshift setup to the Seine which positions the shift lever firmly in the 3rd/4th plane. Thanks, Jim
tobluforu 09-03-2011 01:12 PM
Straight up and it's on the third and fourth plane. Once its in third gear, leave it there, undo rear coupler and it will pretty much just fall into the right adjustment. It will then take a few drives to dial in the coupler just right.
