87 Carrera engine troubles, Help?
Started having some engine troubles today, the car has been outside in the heavy rain on a steep incline facing up (i usually park it facing down) im not sure if that had something to do with it? The problem started last night when i turned on the engine and it seemed normal and was waiting for the car to warm up then it felt like the pistons were really struggling to go and there was a lot of vibration and it eventually stalled out, i tried again and when i revved the car it seemed fine but just starts struggling in idle and i was not able to get out of park on a steep incline. The next morning it started fine but still felt a bit sluggish and couldnt get out of the park on a steep incline, it would just stall out. So i backed it down the hill and turned it around and was able to get it going but it felt like i was going with no power for a few seconds then the gear would engage and it was fine, but every once and a while it would cut out again like there was no power or be really sluggish. I have it parked now near work but i dont want to risk damaging anything.
I also noticed the oil guage (not the oil pressure) was starting to get a bit low in general the past few days. So i was going to check the oil and put some more in today, maybe low oil is not allowing the engine to be properly lubricated?
What do you think this is? Anything i can do to keep it running until i can get the car to a mechanic?
Thanks,
-Ben
Old 10-03-2011, 02:28 PM
Assuming the car was running satisfactorily prior to the rain event, I would suspect that water has somehow got into the intake.......perhaps a look/see at the sparkplugs might reveal if this is the culprit. IF so, then a good cleaning of the fuel delivery system is in order. Hard to say without being there.....
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 10-03-2011, 02:46 PM
Thanks,
-Ben
If you open your distributor cap you might find your problem...moisture! Caps are not water tight and are notorious for wicking water at their base with capillary action, primarily to keep mechanics busy whenever it rains.
Cheers,
Joe
Old 10-03-2011, 02:49 PM
Yes prior to this the engine was running well, but just a little rich (high hydrocarbons) and was going to get adjusted this weekend from the mechanic.
I read a few other posts where people had a similar problem with rain but it sounded like it was with newer 911's and some chip was getting wet.... Do you think waiting for everything to dry out will help this problem?
This is my first 911 and first sports car so im a bit new to all this.
Old 10-03-2011, 02:55 PM
efhughes3's Avatar
Some spargplug wire boots don't like to get wet either.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-03-2011, 03:19 PM
Would you guys recommend spraying the distributor with CRC 5-56? My buddy said every time it rains he has to do that to his Mini. Or will something like this hurt a 911?
Could be the plug wires too. I had wet problems like this last year and the plug wires were worn out. Changed the distributor cap too.
Dave
1985 Factory Turbo-Look Coupe
2011 Cayman S
2012 Audi S4
Old 10-03-2011, 03:21 PM
pete3799's Avatar
The CRC 5-56 will work fine.
Pete
79 911SC RoW
Old 10-03-2011, 03:40 PM
Thanks guys! Will give that a go.
Old 10-03-2011, 03:50 PM
went and checked it, runs fine now. Must have been a combination of the steep parking angle and all the rain. Its been sitting on a level surface for half the day and not very much rain and sounds normal now.
Old 10-03-2011, 05:36 PM
So after work it started up fine and i decided to take it for a long drive to get a feel for the car since the rain incident the morning (i should also mention it is really cold here right now if that will affect anything). At first it seemed normal but the acceleration was very slow in general, especially in 3rd gear, RPM's seemed to have trouble getting past 3000 on the meter (but it eventually did on some long stretches) and in general the dial seemed really slow going up and down than what i remember. So i drove it for a half hour or so to get the engine warm and hopefully get any remaining moisture out of the engine. Towards the end the acceleration came back in second gear but 3rd gear was really slow still (put your foot all the way down and very slowly accelerates)...is this because of the cold?
When i got back to my place and parked it the idle seemed normal but there was more 'popping' than i remember before the rain/stall incident. could this also be from the cold weather?
Old 10-04-2011, 12:27 AM
twistoffat's Avatar
Certainly sounds like your distributor cap has moisture in it. IŽd give it another really good clean just to be sure
Old 10-04-2011, 01:33 AM
efhughes3's Avatar
Porsches run fine in cold weather, you have other issues, it seems.
Ed Hughes
2015 981 Cayman GTS
Old 10-04-2011, 07:45 AM
Might be a good idea to get out the blow dryer and dry out inside your distributor. Keep the blow dryer handy whenever it rains.
Cheers,
Joe
Old 10-04-2011, 08:18 AM
Nine9six's Avatar
Cheers,
Joe
I am assuming you do not have a garage for your Porsche. If that's the caee, standing in water, while using a blow dryer, is prolly not recommended
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-04-2011, 12:14 PM
Hi Ben,
Check condition of your rotor arm and plugs, should be clean and in good condition not oily or black (how many miles on your engine). Do you have water entering the car, stick your hand under the seat where the ECU and DME relay live if you have water entering, it wool pool around this area. Change your DME relay.
Old 10-04-2011, 12:16 PM
yeah it is kept outside at the moment, its been fine since i got it but recently there has been a tropical storm so its been more rainy then normal.
I will dry out the distributor today and see how it runs.
the car has around 91,000 miles on it, no water in the car.
Old 10-04-2011, 01:55 PM
There are 2 screws on either side of the distributor which are a bit hard to get to, is it just something i can pull off or do the screws need to come off first?
Old 10-04-2011, 05:27 PM
Are you talking about the two screws on the distributor cap? Those hold the cap to the distributor so you'll have to undo them. From memory (my car is currently in the UK) they're a little fiddly but not that hard to undo.
Old 10-04-2011, 05:34 PM
efhughes3's Avatar
The screws are part of the cap and are spring loaded. Push and turn 180 degrees.
Old 10-04-2011, 05:39 PM
