Horn sounds funny! 85 911
sounds as though my horn is only half working...not getting the full sound.
Had the steering wheel off and then it started to sound bad..loud but not a full pitch. Noticed my Slip ring was worn...would this make a difference in the sound? OR the Horn Contact? ![]() ![]() ![]() |
ROW '78 911 Targa
Horn contact wire at the wheel creates a ground path that picks up a relay in the fuse panel that feeds both horns on the same wire.
If it picks up, it is working. Check the horns themselves.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 06-07-2020 at 08:38 PM.. |
You may have lost one of the horns high or low. Check the wiring at the horns
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Since I had taken The wheel off to check the reason for the wheel being loose.. could it be something under the horn pad on steering column?
ROW '78 911 Targa
Read my edited post above for clarity.
Ground the brown wire to the horn directly to test if it is working properly. If not, check the horn wiring.
Tags |
horn , horn ring , slip ring |
