JV44HeinzBar's Avatar
Tires for 5.5 x 15 Fuchs
Hi,
I've searched PP forums and haven't really come up w/ any suggestions on a good tire for 5.5x15 Fuchs. Additionally, while searching the net, I came across a chart that indicated that wheels w/ 5.5 width could use 205 tires. I don't believe I've ever seen any 5.5 wheel hold 205s only 195s.
Any advice is appreciated.
HB
Current:
1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun!
1971 911 T Targa Signal Yellow (summer joy)
Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green
Old 09-26-2011, 03:20 PM
Rescuer of old cars
Arne2's Avatar
Honda put 205/60-15 on 5.5" wheels on some Accords in the early '90s. So yes, they fit. But no, they don't fit well, nor can you expect good performance from a tire pinched down on a rim that narrow.
This is from memory, I spent 25 years in tires (prior career).
Old 09-26-2011, 03:42 PM
I agree with Arne2, 205s will fit a 5.5" wheel, but they aren't ideal.
I'd probably go with a 195, or if it exists, maybe a 185.
I run a 205 50 15 on a 15x8 on my miata, and they are also commonly used on a 15x7.
Old 09-26-2011, 03:54 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Historic tires :
-Pirelli Cinturato CN36 185/70-15
-Michelin XWX 185/70-15
-Vredestein Sprint Classic 185/70-15
-Avon CR6ZZ 185/70-15 (more racy)
or go a bit smaller
165HR15 - Michelin XAS is original to a '67S, maybe 68S, ...
Scott Kinder
kindersport @ gmail.com
Old 09-26-2011, 05:25 PM
Rescuer of old cars
Arne2's Avatar
The 165HR15 was original on '69 911T w/5.5" rims. Probably on '70 too.
Old 09-26-2011, 07:26 PM
Thanks gents. The old parts car I picked up has 5 5.5 x 15 Fuchs on it. The wheels are still wearing Pirelli P6s 195/65/15.
I did a quick search at TireRack.com and the applet suggested Goodyear Eagle GTs. The car that will use these wheels will never see snow or foul weather yet the link below suggests all weather tires. I'd like to find some good performance tires that are on the "sticky" side. It's getting hard to find high performance tires for 15 inchers.
http://www.tirerack.com/tires/SelectTireSize.jsp?autoMake=Porsche&autoModel=911&autoYear=1970&autoModClar=&brand=Pirelli
HB
Current:
Old 09-26-2011, 07:30 PM
Rescuer of old cars
Arne2's Avatar
"Sticky" tires + 5.5" rims = much sidewall flex. Not a good package. If you want grip, I'd recommend wider wheels.
Old 09-26-2011, 07:37 PM
Shaun @ Tru6's Avatar
I recommend Yokohama S drives in 195/55/15
Yokohama S.drive
Sidewall is in between a standard 205/55 and the rubber band look of the 205/50. With the 5.5s, you'll get a little more sidewall height than if you were using a 7x15s.
Tru6 Restoration & Design
Old 09-27-2011, 04:02 AM
Thanks Shaun. I'll be sure to check those out.
HB
Current:
Old 11-10-2011, 03:43 PM
racer's Avatar
I ran 205-50-15s on 5.5x15 wheels on my 914. 195/60s as well.. 185/70s too
In the 1970's running a 205-70 was possible and common.
Good link to vintage tires above.. Coker makes some lovely (and expensive) period correct tires that would fit.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 11-10-2011, 05:31 PM
