-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   what gaskets to use? 3.0 carb conversion. (http://forums.pelicanparts.com/showthread.php?t=639183)
jax911 11-10-2011 12:39 PM
Trying to find the right gaskets for top and bottom of insulators for a 3.0 carb conversion.
What does everyone use.
Thanks.
john walker's workshop 11-10-2011 01:04 PM
CIS style at the head and carb intake style above the insulator. do you have the PMO adapter/insulators that block the injector cutout in the head?
jax911 11-10-2011 01:41 PM
I don't know what brand they are but they do block off the notch at the head, but then have a notch on the top of the insulator.
The old gaskets that i took off fit perfectly and didn't have a cut out for the injectors, trying to find those.
VFR750 11-10-2011 02:15 PM
I used a early 1970s 911S gasket (with the 36mm port size) on my 34mm heads/manifold
What size ports are yours, 34 or 39mm?
jax911 11-10-2011 02:22 PM
39 ports. I suppose I could make them since I have the old ones as a template, but never tried that before.
VFR750 11-10-2011 02:50 PM
John has the right answer.
CIS Gasket: 930-110-197-12-M17
the 911S gasket is only ~36mm: 901-108-391-05-M17, so the hole might be a little small.
jax911 11-10-2011 03:24 PM
That one has the notch cut out, is that ok?
VFR750 11-10-2011 04:37 PM
Do you mean the two notches on the outside edges? No issues for me.
