Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Hard Oil Line Question
Hi,
I've put my (Euro 3.0, no front oil cooler) engine in my 69 after previously having it in my 72 911. I've always had a braided stainless line running from the bottom of the engine to the oil tank, but it's developed a leak, so I've decided to go with the OEM hard line. I picked up a hard line from Tom over at CarQuip, but I'm not really certain it's the correct line. I've attached a pic...do I have the right part, and if I do, what else do I need to mount it?
Thanks!
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 11-13-2011, 02:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I posted a similar thread about how to tighten that oil line at the driver side heat exchanger. I have a leak at the nut.
I found it impossible to place a wrench there.
Does anyone know what the trick is?
Sorry not sure if it is the correct hard line for your car.
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 03:01 PM
Aircooled Breakfast
Depends on the exhaust you are running. If you have the later SC/3.2 exchangers then, yes, it's the right line that runs behind the case. If you have the earlier exchangers or SSI's then you need the version the runs under where the case and transaxle mate. -John
Old 11-13-2011, 03:56 PM
DRACO A5OG's Avatar
So how do you tighten it???
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 04:02 PM
Rennch on YouTube
rennch's Avatar
John, I think I need the latter. I have earlier heat exchangers for sure. I'll swap the part...
Michael O'Neal -
Old 11-13-2011, 04:12 PM
DRACO A5OG's Avatar
Michael,
Please keep us posted as how you were able to tighten that fitment at the heat exchanger.
Jim
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 04:14 PM
Chuck Moreland's Avatar
Michael, you need crossover part # 911 107 720 11. This is a special '72 year only part and extends from the case to the '72 only oil filter console.
Lufftwaffle's advise would have been correct for any year, except the '72 like you have.
Jim, You need to remove the heat exchanger. There is no way to get a wrench on there with the heat ex in place.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-13-2011, 04:35 PM
Rennch on YouTube
rennch's Avatar
Hi Chuck...I don't have a 72, I have a 69. I USED to have a 72.
Michael O'Neal -
Old 11-13-2011, 04:48 PM
DRACO A5OG's Avatar
Thanks Chuck, I did remove the heat Exchanger when I replaced the gaskets, but there is no way a wrench could fit in there.
I hate to use a chisel.
'85 Carrera Targa
PCA/POC
ROW '78 911 Targa
timmy2's Avatar
Jim,
I was able to tighten that fitting with the exchanger removed using one of the Harbor freight wrenches I've seen talked about here. Tight fit but I was able to do it without denting my brand new oil tubes!
15 Piece Metric Service Wrench Set
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-13-2011, 05:37 PM
DRACO A5OG's Avatar
Perfect Dennis!
That is exactly what I was looking for! Thanks so much Brother!
My next step was to grind down a wrench or chisel but this is much easier
Jim
Originally Posted by timmy2 View Post
Jim,
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 05:42 PM
ROW '78 911 Targa
timmy2's Avatar
You'll find a dead blow hammer will be your friend while you're under there too! The wrenches are short so either use a pipe on the end to extend it or the afforementioned sand hammer.
Dennis
Old 11-13-2011, 05:53 PM
DRACO A5OG's Avatar
Copy that
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 05:54 PM
Oops, missed that bit about the engine coming OUT of a '72.
Now you have a different problem because the '69 has a 26mm fitting on the tank. The 3.0 liter has a 30mm fitting.
The correct OEM crossover part for the 30mm fitting is 91110773910. But the OEM mating hose 911 107 728 00 will not fit directly onto the tank.
You can use the OEM hose # 911 107 728 00 with our 26mm to 30mm adapter our # 0121100. You may need to have the hose shortened on the OEM line to accommodate the length of the adapter, sometime you do sometimes you don't.
Draco, don't use a chisel. You should be able to fit a wrench on there, though I know the oil return tube does encroach. You need to get the right angle on the wrench, but it does work.
Last edited by Chuck Moreland; 11-13-2011 at 08:58 PM.. Reason: corrected part number
Old 11-13-2011, 06:00 PM
joefrantz's Avatar
Draco
This little doodad works great on that connection. Doesn't interfere with the return tubes. Put it over the line first, and slide it sideways onto the nut.
I just tightened mine this afternoon. I keep this wrench just for the one application.
Joe
Pelican Parts - Product Information: PEL-PW-OLW
Joe Frantz
73 911 T
Old 11-13-2011, 06:36 PM
DRACO A5OG's Avatar
emptyo, sorry to have hi-jacked your thread, but I am certain you will see how difficult it will be to tighten that nut.
Thanks fellas, for the leads.
J
'85 Carrera Targa
PCA/POC
Old 11-13-2011, 07:50 PM
ROW '78 911 Targa
timmy2's Avatar
I have the wrench Joe Frantz mentioned as well. Didn't use it for that spot. I probably just grabbed what was on the bench when I went to tighten it. I'm sure it would do the trick too.
Dennis
Old 11-13-2011, 09:00 PM
j911brick's Avatar
I think your asking for trouble if you don't convert the entire cooling system to 30mm.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 11-13-2011, 10:14 PM
Walt Fricke's Avatar
I think the simplest system for tightening the engine case oil fitting is to install a removeable oil return tube at that one spot. Then no special wrenches are needed, and you can counterhold the case fitting while tightening (and especially when loosening) the oil line nut. You are apt to be doing this parts swapping in conjunction with an oil change (or at least a drain) anyway, no?
Old 11-13-2011, 10:32 PM
