Glue
What kind of glue should I used on rubber trim that has gotten lose. That wont hurt the paint?? Thanks in advance.
I use 3M super weather strip adhesive BLACK! The spray does not seem to have enough power and gives up over a period of time! Plus before everything has set, you can slean it off with Brake cleaner. DO the testing and know what brake cleaner works and what does not because they are all different and som will not hurt the paint and some will not remove anything including the grease (Vavoline Brake cleaner is the worst I have ever used and I like most of their products!
You can buy it at the big box car part stores. Black and red tube. Suggest only using this. |
Thanks, $10 a tube.autozone.Anybody need the remaining 98% in tube..hehe
Don't worry you will use it allot, I sealed all my pin holes on the tub in the cab and under the dash at the foot wells.
Stuff comes in handy. |
