jsveb's Avatar
Front shocks need help ID and disassemble
Hi
I want to take the top mount off my front shocks on my carrera 3.0
I simply Cannot make the nut move. What is the trick? I have had it in a vise etc. now it is soaking in PB.
I do not have a special strut tool.
Btw The struts are off the car along with the top mount.
Also, how do I ID what type of shock insert I have. There is no numbers on the housing. It is just black. Can it only be determined once I have removed the insert?
Just for info. The backs are yellow Konis.
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 12-20-2011, 11:47 AM
Platinum Member
dad911's Avatar
Spin it off with an air/impact gun.
Old 12-20-2011, 12:23 PM
schumicat's Avatar
leverage. use a breaker bar with a pipe over it to make it longer. I use a hollow jack handle.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-20-2011, 01:04 PM
Gordo2's Avatar
Black Strut Housing
Black normally = Boge struts and originally Boge strut inserts. A few choices for replacements by Boge, Bilstein and Koni.
I think I used a pipe wrench to break the top nut free.
Good luck,
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 12-20-2011, 07:05 PM
ivangene's Avatar
internal or external threads? mine were external so the "nut" had a hex (allen) shape in the top... I made a steel hex to fit inside and a hole to go over the shock...then a regular wrench....didnt damage any paint or risk distorting the nut itself. came off easy...then drained oil all over the place and made a mess
Ed M
86' Coupe
Old 12-20-2011, 07:40 PM
