Idle trouble
Hi
First post, hope this is the right place.
Having some trouble with my '84 3.2. I don't use the car much (about 700 miles in last three years), and recently after starting her up have been getting a very, very rough idle. I tried air flow cleaner and removed the ICV and cleaned thoroughly but still getting a rough time. Below 3000 rpm it shudders and is reluctant to rev, then, over 3000 rpm it pulls smoothly and strongly.
Also, a very rich smell while running.
I'm thinking it's down to lack of use, the ICV and plugs have become fouled. Would appreciate input from anyone who's had similar trouble. Beyond what I've described it's probably a trip to my mechanic but would appreciate thoughts.
Thanks,
TPD
Old 01-29-2012, 08:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Welcome aboard!
Do you have a back up DME relay, if so swap and see if it clears up
Try some Stabil fuel stabilizer or even Seafoam to get potential moisture out of the Fuel.
A tune up may help as well, plugs, rotor and cap, remember to drop some lube down the felt pad in the dizzy or at a minimum an Italian Tune up after she is proper warmed up.
For god sake driver her more
Do you have a pic of your baby?
Jim
'85 Carrera Targa
PCA/POC
Old 01-29-2012, 09:01 PM
DRACO A5OG's Avatar
Oh yeah, also check for vacuum leaks,
'85 Carrera Targa
PCA/POC
Old 01-29-2012, 09:09 PM
muck-raker
kidrock's Avatar
"I'm thinking it's down to lack of use..."
Certainly, that will do it. These cars need to be driven, there are dozens of threads like yours where a P-car isn't driven much and displays the symptoms you describe. When you say "lack of use", how much "lack" are we talking about?
And, just like Draco says above....DME relay, plugs, rotor, cap, vacuum.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-30-2012, 06:50 PM
the list could be long, including bad gas, varnish in the fuel filter and injectors, etc etc.
+1 on driving it more.
Old 01-30-2012, 07:20 PM
I've tried a new and known good DME but no joy. Bad fuel maybe.... how unlucky would I have to be???
I tried an italian tune up but gave up after 30 mins. (M&K exhaust isn't polite in my 'hood...) Why would it be good under 3K and pull normal above?
I will try to drive it more but I have a difficult garage arrangement.
As for a pic, well, it's a red 80's 3.2 with spoiler and tail. Look up 80s yuppie dream car ;-)
Appreciate your advice.
Thank you.
TPD
Originally Posted by DRACO A5OG View Post
Welcome aboard!
Jim
Old 01-30-2012, 09:53 PM
DRACO A5OG's Avatar
Oh she is a beauty Likee the eruo turn signal lenses...
When was the last time the Fuel Filter was changed? Try removing the filter to see if there is debris at the inlet port. With the freakin E10 gas our rubber fuel lines really do not like sitting gas in lines. A recent poster found his filter clogged, he removed and cleaned out the debris and his baby is all well now.
Try some Techron/Seafoam with top off of gas. Make sure the ratio is proper too much of a good thing is bad.
'85 Carrera Targa
PCA/POC
Old 01-30-2012, 10:11 PM
aj88cab's Avatar
I'd put the idle switch on the list of items to check also. Its located on the back left side of the throttle body.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 01-31-2012, 05:30 AM
Chain fence eating turbo
When you first start it, does it run fine and then as it warms up start to run rough?
Old 01-31-2012, 05:57 AM
BTW, yo soy TresPuntosQuatro
I really don't know Spanish though, just liked your name.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-31-2012, 09:19 AM
Nine9six's Avatar
Drain the old fuel, replace the fuel filter, refill and add a can of BG-40, then drive it all the live long day. If this does not clear up your problem, check for air leaks, Warm-up regulator (WUR), and possibly failing O2 sensor.
HTH
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-31-2012, 12:45 PM
There's not a WUR on a Motronic.
Old 01-31-2012, 04:15 PM
Nine9six's Avatar
You're right Tips...I dont know what was I thinking...But I do like the suggestions you made to help resolve the idle problem.
96 993 C2 (Current)
Old 01-31-2012, 04:38 PM
76 911S Targa
The best advice you have received is to discard the old fuel. Modern gasoline formulations do not last more than a few months, if that. If you have only driven 700 miles in 3 years, how old is the fuel in the tank? This is the cause of your rough running. Drain and refill the fuel tank and use at least one container of fuel injection cleaner such as Techron or SeaFoam to help clean the deposits in the injection system. Replace the fuel filter. Then drive your beautiful car a whole lot more than you have been. When was your last oil change? There may be condensation in both the fuel tank and the oil tank if the car has sat this long. I don't see your location but if you live in a cold wet place condensation can be a real problem. If you live in a warm dry place, maybe not an issue. Drive it for a short interval and then change the oil too.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 01-31-2012, 04:44 PM
Quote de Tippy
I'm not gonna blurt out a bunch of stuff until I understand things in a systematic approach.
This place is full of "DME relay" solutions to problems costing many here unnecessary money.....
Old 01-31-2012, 05:31 PM
Before doing anything else, I would pull the spark plugs and replace them. And if that doesn't fix it, take it to the mechanic.
Nothing like starting with the basics.
Old 02-02-2012, 10:29 AM
