I'd like your autocross-related wheel/tire advice...
I currently have 2 sets of wheels/tires for my car. The set that's currently on the car are a size upgrade from the original, which came of an early 993. I've got 16x7.5's in the front (205/55's) and 16x9's in the back (245/45's). I just put a new set of Kumho's on them, and did an autocross on them about 200 miles ago.
I also have a set of original size Fuchs (16x7's and 16x8's) with some Yoko's on them with lots of tread left. The tires are a model I had never heard of before: A540's (VR rated). I'm not sure how good they are; I did a pretty quick mountain drive with them, and I didn't fly off the road, at least. Anyways, I had originally planned on using one set for autocross and one set for everyday driving. I like the looks of the 993 wheels best, and would like for the Fuchs to be the autocross set. My question is: If I autocross with the Fuchs, would I really be sacrificing a lot of handling by using the smaller sized wheels? What if I put autocross tires on them? Or should I try and take advantage of the larger wheel sizes and put autocross tires on them, instead? |
Automotive Writer/DP
I assume the Kumhos that you have are not R compound tires and that the 993 wheels could be used as is for the street. I think as long as you are not competing for fast time in your class, you could learn alot with the tires on your Fuchs. If you decide to go to R tires, try to fit a 225/50 on the front and a 245/45 on the rear if you can.
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
For autocrossing, the smaller-diameter wheels are better, unless you have endless amounts of torque on tap. Autocrossing rewards quickness.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
randy-
well, i still consider myself in learning mode, and autocrossing with the fuchs would at least allow me to burn up the yokohamas without spending any more money right now. i like that idea, although i'm pretty confident the yoko's i have aren't as good as the kumhos. i'm looking for the best compromise for both applications. the kumhos i have are the ecsta 712's. good street tire, not the stickiest, though. 225/50's won't work on the front because of rubbing problems. i've tried them already with not such great results. thom- both sets of wheels have a 16" diameter. Last edited by adamnitti; 04-14-2002 at 03:09 PM.. |
