I finished adjusting the front ride height after replacing all the bushings and Torsion bars. I have noticed that the adjusting cap is free to float a little from front to rear. What keeps the adjusting screw from backing out, thus changing the ride height over time? I notice some blue stuff on the the threads when I took it apart.
12' GT3 18’ 991S |
avi8...I found the blue stuff also..I imagine it's loctite..Your front adjusting screw is pressing in for height adjustment? I didn't use loctite on resetting. non-pro writing...been OK for 20k miles..I figure it's one of those tweaking areas anyway...Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
