fxeditor's Avatar
What causes this on a distributor cap?
Hi all,
I am doing a tune up of my 1987 Coupe when I ran across this problem. I pulled the plug wires going to the distributor cap when I saw the #1 prong covered in rust! Please see the picture below:
This cap is only about 2 years old. What causes a problem like that? Moisture trapped between the plug and wire? I haven't pulled the plugs yet to see their condition but I'm assuming the #1 plug isn't going to look great either!
Thanks for looking,
-Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 04-04-2012, 01:09 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Rust is the name of iron oxides that forms when iron corrodes and is caused by the reaction of iron with oxygen. Rust is formed when oxygen dissolved in water reacts with iron. There are always two different reactions in a corrosion process:
1) oxidation of Iron
2Fe ---> 2Fe2+ + 4e-
2) reduction of Oxygen
O2 + 4 e- + H2O ---> 4OH-
The overall reaction is:
2Fe2+ + 4OH- ----> 2Fe(OH)2
Fe(OH)2 reacts with oxygen to form Iron oxides: Fe2O3 (hematite, red rust), Fe3O4 (magnetite, black)
Gary R.
Old 04-04-2012, 01:12 PM
fxeditor's Avatar
Thank you professor Smart A**. Why is it on my distributor cap?
-- '92 Miata
Old 04-04-2012, 01:23 PM
dshepp806's Avatar
Because of the H2O piece of the equations...
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-04-2012, 01:37 PM
Nice chemistry lesson, Gary.. Michael, I use silicone dielectric grease at the connections, both cap and plug, to keep this from happening...
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 04-04-2012, 02:18 PM
76 911S Targa
Because you live in California and not in the salt capitol of the world, on the east coast, I suspect that on this single lead that you had some contamination. This is what we see happen to our cars where the roads are salted in other parts of the US. You had the unfortunate experience, though a minor one, or having this happen to a single contact on your distributor cap. Any humidity in combination with salt accelerates corrosion of ferrous metals via a process called chelation. It also isn't too good for most other metals as far as that goes. I suspect that when the cap was installed, the person who did so perhaps had some salt on his or her fingers (potato chips plus beer = better mechanic experience) and touched this single contact point. As the previous poster says, use some dielectric grease next time and it will help minimize this occurrence. Most caps and wire sets come with a small packet of grease for this purpose.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-04-2012, 02:28 PM
dshepp806's Avatar
I ALWAYS clean the hey out of those connectors (even an occasional burnish),...Bosche dielectrical grease galore,..then physically mount those babies as tightly as possible...I've never seen such as demonstrated in the pic...that is pretty wild, you must say. Clearly moisture prevailed there.
Get her changed out and go from there!
BEST!
Doyle
Middle Georgia
Old 04-04-2012, 03:07 PM
fxeditor's Avatar
Thanks for the help on this everyone! You're absolutely right TargaLid Being a socal lad, I really haven't had too much experience with this "rust" thing you speak of! That being said I ran down to my FLAPS and bought a bunch of dielectric grease which I'll be using on both ends of the plug wires.
Take care,
Michael
-- '92 Miata
Old 04-04-2012, 07:32 PM
Hi
Targa Me's Avatar
In all my years of working on cars, I have never seen rust on a Dis Cap like that.
My 911 is a DD and is in the rain during the winter seaon and I've never seen that.
i think its odd.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 04-04-2012, 09:02 PM
tazzieman's Avatar
2 questions:
- The condition of the boot on the lead attached to this terminal? Microscopic split?
- Did you notice any symptoms? The 911 will run quite well on 5 cylinders , and on 4 though then it has the pull of a VW Beetle. The plug condition - please report back with a pic.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 04-04-2012, 09:22 PM
DanielDudley's Avatar
That was wet in the cup for a good while.
Old 04-05-2012, 03:42 AM
docrodg's Avatar
That can't feel good, especially when walking!
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-05-2012, 04:49 AM
fxeditor's Avatar
Originally Posted by tazzieman View Post
2 questions:
Thanks for the reply! I got called into work for an emergency so I wasn't able to pull the plugs yesterday. I'll knock that out today and report back.
As far as the plug wire goes, it is a 2 year old Magnecor wire. I checked the boot for any splitting but didn't see anything.
I was experiencing symptoms. Rough idle, lack of power, and a failed smog check (lean condition) all prompted this tune up.
-Michael
-- '92 Miata
Old 04-05-2012, 08:19 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Water causes that. Use a dab of dielectric grease on the boot next time.
Old 04-05-2012, 08:45 AM
