-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Too much tranny fluid consequences? (http://forums.pelicanparts.com/showthread.php?t=683830)
Packy 06-15-2012 02:48 PM
What are the consequences for having too much tranny fluid on your 915 transmission? When I fill the tranny it's usually jacked up with the butt in the air and I fill it until I can feel the fluid with my finger down in the fill hole.
I have two 915s and they both seem to leak out of the bearing on the rear end of the tranny where it bolts up to the clutch, motor, etc.
Any input? Could it be TWO bad bearings? The leaking only really happens when it is warmed up. I figure the aluminum case is opening up and letting the tranny fluid to leak.
Any advice would be great.
Thanks,
-P
Packy 06-15-2012 02:51 PM
BTW, with my other tranny the problem would be the fluid leaking on the clutch and it would vibrate after it warmed up. Usually after driving the car for a good 15 minutes and this would cause the clutch to slip and shudder.
Jerome74911S 06-15-2012 05:06 PM
My understanding is that the item indicated by the arrow is a vent, and excess pressure (or too much oil) is expelled through the hole that faces forward. You may also have some bad oil seals, not necessarily bad bearings.
http://forums.pelicanparts.com/uploa...1339805190.jpg
RWebb 06-15-2012 05:28 PM
that is indeed a vent and P AG wants it to face a certain angle too
do not rely on it to "expel" excess gear oil
do the gear oil changes on a flat surface -- sit some timbers under the car if no lift, or use 4 jack stands; it's not as if you are doing this every week
Packy 06-15-2012 06:19 PM
anyone have a dimension on the distance from the end of the guide tube to the seal on the inside of the guide tube? This is the input shaft seal. I want to make sure this seal is in the right position on my back up transmission. Anyone know this?
