I need some help.
I had to do some work on my Parking brake and forgot the order of the washers, heater senors, and 2 heater/defroster handles. This is on a 1977 911S. If someone could take a CLOSE-UP picture looking down over the handles that would be great. As I said, I am looking at everything outside the brake handle on the passenger side. I looked at “Pet” from Porsche however; it’s not clear on the order. Thank you in advance for any help you can provide. |
The Bavarian
![]() This is for 78-83. Hope it helps. - Manfred |
ManniB
This is what I was trying to use however, it's to busy and I can not tell what goes where in what order. However, I do want to that you for sending it to me. maui44 |
The Bavarian
Actually it's not that difficult. Part 21 are the big washers that go in between the different other parts. Part 23 is the carrier/holder for the heater ventilator switch in the engine compartment. Part 22 is a washer with a nose that its into part 23.
- Manfred ![]() |
The heater ventilator how is it suppose to work?
I do not think mine is working any way to test? |
