I bought a 69... had it on the lift.. check the rust situation.. after you do that, check it again, then again... I made a mistake.. dont let it be you.
JP '76 911s Ice Green Metallic bone stock |
The car number is 911T 9112100980, engine number 6461392 911/82. Found rust in places I missed at first look. Patch was made below pedals. Car would run for two seconds after squirting gas in the carbs. The electric gas pump was running and making pressure on the gauge before the carbs but motor would not stay running. The owner seemed happy to let it sit. Thanks to every one avoid what could have been a expensive mistake.
