-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   How hot does it get in there? (http://forums.pelicanparts.com/showthread.php?t=699382)
OsoMoore 08-27-2012 10:49 AM
I'm thinking about putting various things into the engine compartment on my SC, but I'm not sure how hot it gets. Has anyone run tests with a thermometer? How hot does the block get? What about the air temperature off in one of the back corners of the engine bay?
bkreigsr 08-27-2012 11:01 AM
On my 85, 3.2L, the block is 10-20 degrees hotter than the oil temp, the air - on a hot August day in NJ, after a spirited drive - gets in the neighborhood of 200 degrees in the recesses you're talking about.
In an air-cooled motor, all measured temps will be relative to the ambient temperature.
Bill K
OsoMoore 08-27-2012 11:12 AM
That's not too bad - I'm thinking about rigging some 120mm fans in line with the hoses from the engine fan to the heat exchangers. I can get 200 cubic-feet-per-minute fans fairly cheaply, but I don't know how they'll hold up under high temperatures.
Essentially the system would look like backdated heat except there would be a fan inline with the pipe on each side.
EDIT: Here's a spec sheet for one such fan. Sadly, its only rated at 70C (158F)
http://www.nidecamerica.com/fanpdfs/va450dcf.pdf
