rfix'n's Avatar
vacuum line diameter
Are all vacuum lines on a CIS car the same diameter? Trying to sort out some CIS stuff and want to replace lines but not sure about replacement hose size.
Also replacing a window motor, past threads have mentioned white lithium grease for the regulator. All I have found locally is black lithium. Sources?
Thanks much.
Rob Fix
'78 3.6L SC Targa
Eiche Gruen Metallisch
Old 06-12-2002, 12:54 PM
Senior Member
Hello
Hmm the thines lines are the 3,2mm ID followed by the 4mm iD.
You also can have a short 7mm ID hose.
I would look into a parts catalouge to identify the needed lines and on the old cataloges you also could see the lenght to cut.
White Lithium is mostly used in the food industry.
However any grease is better then nothing.
Grüsse
Old 06-14-2002, 02:44 PM
