Wastegate question
The gasket in my wastegate needs to be replaced. I get that nice loud metallic pop when the wastegate closes. So, while I am at it, should I just rebuild the whole wastegate or get a new wastegate or install a 1.0 bar boost spring? Also, can I run an ebc without the 1.0 bar? I know that I need to do something soon, and don't want to go to the trouble of replacing the gasket and then find out I should have done something else at the same time. Thanks for any help.
1987 930 It goes faster then I can drive it. |
Rebuild. The EBC will work fine with the .8 spring. Put the rest of the money in the future 930 upgrade shoebox.
David 89 turbo cab
