MIK911's Avatar
Question HELP-engine stalls w/ oil cap removal
With engine running, when i remove the oil filler cap (as if to check the dipstick oil level), the engine sputters, and stalls out. Why? How to fix? I believe the 02 sensor may have been disconnected by previous owner-would this contribute to this problem?
Old 08-13-2001, 09:50 PM
GB83SC's Avatar
Post
The hose that goes from the breather to your oil tank needs a small restricter to compensate for the open vacuum. You can also get this result by using vise grips on the hose.
Hope it helps.
GB83SC
Old 08-14-2001, 03:54 AM
