Worked on installing mechanicals and wiring
Old 06-27-2019, 01:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8061 (permalink)
Gordo2's Avatar
Maintenance
Oil change overdue with 232,633 miles on the odometer... Knocked out a trans fluid swap while I was at it.
Don "Gordo" Gordon
'83 911SC Targa
Old 06-29-2019, 12:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8062 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
While waiting for a couple of Pelicanites for a breakfast run, I decided to check the lights around the car.
When I got to the rear passenger light assembly, I thought it was odd that I could see the light bulb filament. After checking the driver side, it was obvious the something was missing on the passenger side.
It did look like that some reflector was missing. The bad part is that I had the car for 10 years and I had never notice it...
After doing some Google searches, the US version has a lamp and an "Internal Reflector" as a side marker. I was hoping that it had came loose and would still be within the assembly. Not such luck and I could not find a part # for it.
Hopefully my Navy mate Richard (Pors1968) got one floating around if not I might have to fab one.
If anyone knows the part number for the Internal Reflector (circle in red) please post it.
Who Will Live... Will See
Old 06-29-2019, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8063 (permalink)
Undocumented User
McLaren-TAG's Avatar
Just cut a piece of florescent lighting plastic diffuser like the umpteen billion of them you see in old office buildings. never be able to tell the difference.
Old 06-29-2019, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8064 (permalink)
JJ 911SC's Avatar
Yes, that is what I meant by Fab one. Actually I got probably some broken one somewhere downstair.
Its probably what they did as the "original version" is two piece glued together to give it some thickness rigidity.
Old 06-29-2019, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8065 (permalink)
Hendog's Avatar
I rolled it...
...over to 140k Km on the odometer this morning on my way to Kelowna. I took the longer twisty route but enjoyed it the whole way. I started out at 6:15 am and got there 5 hours later. I actually found myself smiling at times as I drove along. Ya, I like this car.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 06-29-2019, 07:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8066 (permalink)
Old 06-30-2019, 05:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8067 (permalink)
JJ 911SC's Avatar
Made an Internal Reflector for a Rear Light Assembly using an Ikea tray and driveway marker.
Original
DIY version
Old 06-30-2019, 12:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8068 (permalink)
Pedro '84 Coupe's Avatar
Flushed the brake fluid. Used the "air only" method for the first time with my pressure bleeder. Worked great and didn't have to worry about the hoses rupturing. Also found that one of the inner CV joint boots was torn
2000 Boxster S and 2016 Audi A6
Old 06-30-2019, 12:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8069 (permalink)
Bill Douglas's Avatar
I changed the gearbox oil. Swepco 201 90 grade. The old oil after three years still looked great and no metal filings on the drain plug. So smiling.
Old 06-30-2019, 02:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8070 (permalink)
Banned but not out, yet..
RSBob's Avatar
Drove it to a parking lot (car park) and then drove it some more with its new and old friends
Old 06-30-2019, 09:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8071 (permalink)
In regard to my gearbox oil change.
The car shifted well already, but shifts beautifully well now. I can really fire it through from first to second. I could always shift down to first which I believe not all 915 boxes like to do.
I also gave it an Italian tune. There is a steep, very steep, road and I hit 60mph in second while really under load. It's not about the rev's it about the rev's while under heavy load
Old 06-30-2019, 10:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8072 (permalink)
Fahren mit dem Wind.
mhackney's Avatar
On my 83 SC Cab:
1) JWest Headlight Relay kit (easy install)
2) headlight on warning buzzer (home brew) - I've been meaning to do this for 11 years!
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 07-01-2019, 05:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8073 (permalink)
SoCalSK8r's Avatar
I need to do bleed my brakes too. The last time I did mine was when I had my calipers refreshed and I installed a set of speed bleeders. I need to pick up a pressure bleeder and try that method.
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 07-01-2019, 10:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8074 (permalink)
Needed a "clean" day...so it was detail time.....
Old 07-01-2019, 11:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8075 (permalink)
Putting on new brakes from Eric (PMB)... having a little trouble freeing the brake lines to replace the flexible lines! Haven't been moved in a long time!!
1971 914- original owner
1973 914 2.0
2018 911 carrera T
2016 981 Spyder PTS
Old 07-02-2019, 07:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8076 (permalink)
Eva
911SauCy's Avatar
Drove it, Monday, yesterday, today...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 07-03-2019, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8077 (permalink)
Vendor
Fabspeed Motorsport's Avatar
Location: 155 Commerce Drive | Fort Washington, PA 19034
Work!
Hamsa Naser
Hamsa@fabspeed.com
W: +1 267 742 3006
Old 07-03-2019, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8078 (permalink)
Originally Posted by mhackney View Post
On my 83 SC Cab:
Mind sharing the buzzer info? Nothing like driving to work in the dark and parking in a lighted garage where you don’t realize/remember your lights are on.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 07-03-2019, 04:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8079 (permalink)
Dial 911
A horse with no name's Avatar
Thumbs up Smiles
So do I Henri! ...Also your wheels!!
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 07-03-2019, 11:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #8080 (permalink)
Tags
fuchs are ugly , stock sucks
