French Import
zippy_gg's Avatar
You guys are making me feel bad, with all your projects. All I did was just out and drove my car.
Absolutely nothing wrong with that. In fact I would rather drive the darn thing than working on it!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-04-2014, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1701 (permalink)
Wildman Emeritus
Moved my new used window trim to the basement to await strip, blast and re-anodizing. Also took delivery of a new headliner from our host that will be dropped at the paint shop shortly.
Also been here looking for more places to spend money. Cannot wait to see the finished product in April!!!
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 01-04-2014, 08:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1702 (permalink)
ncseahawk's Avatar
Installed Rubber Window bumpers
after reading the other post on while the door is open...my door had been rattling.
Fashioned rubber bumpers from hand sanding pad by cutting off the two ears and then cutting them down so that they fit neatly in the bottom door channel. Super cheap and super effective.
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 01-04-2014, 05:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1703 (permalink)
French Import
zippy_gg's Avatar
Car now up on ramps in the rear and jack-stands in the front.
Front calipers, front condenser and everything around it removed.
Getting ready to drop steering rack, brakes, and suspensions for an overhaul.
Gilles & Kathy
Old 01-04-2014, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1704 (permalink)
79 Euro's Avatar
01/04/14 - What an unbelievable day - drove around DFW in 68 degree weather! Cold front comes in tomorrow.
Andy Kay
Kennedale, TX
817.948.8538
1979 911 SC Euro - Guards Red
Old 01-04-2014, 06:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1705 (permalink)
Installed a new door lock inside the door on my 911. Had to take the window frame out to get to the lock. Was a really fiddly job. I installed it at least 4 times to get the strap bolt right [RS interiors] and the lock mechanism right.
Also the new lock was a bit tweaked so I had to bend the lever that the out door handle pushes in. Also the corner of the frame was not 90 degrees so I had to put the lock in a vise and fix that too.
With all that hand fitting it finally worked well.
I am glad I have RS door panels.......makes things simpler and easier.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 01-04-2014, 06:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1706 (permalink)
resident samsquamch
sand_man's Avatar
Removed the SAI (secondary air injection) system and plugged the injection ports
Removed the non-functioning cruise control unit from the engine (wouldn't use it anyway)
Cleaned the ISV (idle stabilization valve)
Readjusted the throttle cable
Next project:
Replacing the ridiculously large heater blower motor with the much simplified RS heater duct
-jeff
Old 01-04-2014, 06:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1707 (permalink)
KBOUSTANI's Avatar
drove it and i got a big smile on my face and then rewarded her with a hand wash and wax.
76 carrera 3.0 SSI W/M&K 1RARE76/]89 carrera 4 (964)SOLD
87 targa 3.2,fabspeed cat bypass,sw chip,m&k exhaust(sold)94 carrera 2 cabriolet(sold)00 carrera 996(sold)
95 993,red,meanest looking one(sold)
83 911 sc targa,my first porsche(sold)
Old 01-04-2014, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1708 (permalink)
Worked on rust removal on the front. Disassembled speedometer to figure out which odometer gear I need...
Old 01-04-2014, 08:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1709 (permalink)
Pelican Parts Vendor
BRAIDusa's Avatar
So did I:
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 01-05-2014, 12:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1710 (permalink)
beren's Avatar
Got my car up on jack stands for the first time...pretty lame compared to all your great projects, but feeling great. Used the torsion bars and covers for points. Jack/stands from the sponsor worked great.
Now I can see all the things that need work. I see oil lines weeping at the cooler and oil tank, oil weeping at the crankcase, I think brake fluid is leaking at the left rear brake (fluid is on the wheel and tire), and that the PO must have had a gravel driveway because there is gravel stuck everywhere fore and aft of the wheels.
I also notice that a right oil line on the right front near the jack point is partially crushed. Not good.
beren
Old 01-05-2014, 02:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1711 (permalink)
Installed a new shift shaft seal, changed the transmission lube and rebuilt the shift shaft coupler. 83 SC
Old 01-05-2014, 06:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1712 (permalink)
techweenie's Avatar
Finished installing the Makore veneer in my dash. Still some detailing to do...
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 01-05-2014, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1713 (permalink)
Driver, not Mechanic
I installed a Rennline fire extinguisher mount.
Old 01-05-2014, 07:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1714 (permalink)
BRAIDusa's Avatar
Dug it out.
Paul Eddleston
BRAID Wheels USA
Old 01-06-2014, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1715 (permalink)
cycling has-been
bkreigsr's Avatar
Originally Posted by BRAIDusa View Post
Dug it out.
I can dig that, man
ps- thanks for your sponsorship of the Parade
Bill K
Old 01-06-2014, 08:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1716 (permalink)
Carl83911's Avatar
1. Valve Adjustment that was 30K overdue. all valves were off spec and 4 were stuck shut.
2. Cleaned the sump screen. havent done that in over 60k. only oil and filter change.
nothing alarming from the screen. oil was pretty clean.
3. Changed oil grade from 10w/40 to 15w/50 Mobile 1.
Read that 15w/50 has higher content of Zinc and Phosporous
Carl,
Old 01-06-2014, 09:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1717 (permalink)
French Import
zippy_gg's Avatar
Front suspensions and brakes out of the car and mostly disassembled.
More progress was made since I took the picture this afternoon but I ran out of daylight.
Issue with the calipers: 1 piston stuck in each...
Next I'll try the grease gun trick
I found the official color plate in the frunk
Gilles & Kathy
Old 01-08-2014, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1718 (permalink)
testa-rossa's Avatar
I got air!
Old 01-08-2014, 08:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1719 (permalink)
French Import
zippy_gg's Avatar
Originally Posted by testa-rossa View Post
I got air!
And hot water too it seems!
Nice compressor!
Gilles & Kathy
Old 01-08-2014, 09:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #1720 (permalink)
Tags
fuchs are ugly , stock sucks
