'78 911 Coupe
Replaced my luggage compartment trim with polypropylene material. This is the stuff the VW guys use on door card panel rather than particle board. The front side has a leather texture!
continued to revert to stock. replaced the stock air box and cruise control module.
in the process found my little vac leak. a small vac hose had come off the oil tank vent module. ![]() next put back the HVAC blower. almost there. ![]()
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
French Import
From here:
![]() to here: ![]() to here: ![]() ![]() ![]() Engine now installed but it was too dark to take pictures... A big thank to Jim (DRACO50) for coming all the way over, with specialized tools and knowledge. In the process we found that my ATV jack would not stay up, and fortunately Jim brought his... just in case! ![]() Note/tip 1: Do not install the AC compressor before installing the engine; it simply will not clear the rear/right gusset. Note/tip 2: If you installed a hi-torque starter you will find it very difficult to reach the nut that holds the thick positive black cable and the red positive cable, all located on the right side of the transmission. Jim discovered that it is much easier to reach over the transmission body (left side of the transmission). More work to complete Note/tip 3: Be sure your injection wire/connector in the front of the engine does not get stuck behind the firewall, or you will face a partial drop to resolve this. DAMHIK ![]() Note/tip 4: do not install the heater blower intake piece until AFTER you connect the CHT and both reference sensors Note/tip 5: Have Jim's number on speed-dial! ![]() Yup, this was my first drop and re-install so I made notes of my mistakes...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
French Import
Helas je ne vois pas sa marque preferee, ni la mienne...
What are they and I'll see what I can do...
![]() installed supersprint full exhaust |
Cars Ruined My Life
Added side script and center stripe(s).
Starting to put the car back together re doing the entire electrical system added a baterry cut off switch.
78 911 st backdate 87 944 00 996 |
Kanuck, very nice look! I like it!
I blasted my tail light housings and found some di-electric wasting on one - anyone know good ways to fix this? I've got Spoke setting me up with full front and rear LEDs. Before ![]() After ![]()
84 911 Targa Carrera currently getting renewed |
Nothing compared to what most of you get up to - I drained my transmission fluid and refilled with Swepco 201. Looking forward to seeing what it does my my 915 feel.
1983 911SC 2005 911S |
Pelican Parts Vendor
Parked it then drank some coffee.
image by Team Illuminata Motorsport, on Flickr image by Team Illuminata Motorsport, on Flickr
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
Runnin on empty
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
Made it pop!
www.classicretrofit.com |
^ That looks great! Can you share details on the mirrors?
Cheers! They are period Hella 4004GT mirrors. Usually you see them mounted on the wing/fender tops of 240Z Datsuns and some the Kamei racing VW Golfs. You can get them in chrome too.
Thanks, looks cleaner w/o the mirror bases!
| Tags |
| fuchs are ugly , stock sucks |
