carrerarsr65
928 sleeve removal?
ok guys tried this moring to remove 928 sleeve very difficult basiclly what happened is i got the top half of sleeve off but the rest is still in the steering colum/between bearing and shaft, so my ? is can i maybe drive the rest down with a small punch or maybe a really small drill . idont know i open for any suggestions thanks for all the help with trying situation oh ya the sleeve is now flush with bearing surface no way to grab it!!
Old 04-16-2013, 02:28 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The amount of width/surface area that the bearing covers on the shaft is rather small. Get a stiff tool like a drill bit or similar to tap the sleeve remnants further down the shaft and you should be fine. I suspect you're making the switch to the Mitch Leland bushing?
Kevin L
'86 Carrera "Larry"
Old 04-16-2013, 02:36 PM
carrerarsr65
ktl
you got it brother leland all the way
Old 04-16-2013, 03:51 PM
