Loss of power during spin/ fishtail
2005 Carrera 997 S
Today after AutoX I stayed in the empty lot and decided to mess around a bit. It was raining and the lot was wet and slick so I wanted to push limits and learn something.
I had sport suspension engaged and PSM off.
I noticed that on hard acceleration in during a turn when the rear began to hang out I lost power. I began to do it purposefully to figure out what was going on. I noticed that when the rear really started to swing out and I hammered the accelerator - trying to purposefully counter the fish tail with adding power - that the car dropped the revs. It was almost as if there was some safety feature kicking in that was not allowing me to add power during a spin. Note that I had the PSM OFF. I cannot understand why I could not power my way out of the spin - it just would not let me. It was not a fluke because I was able to consistently replicate it. It almost felt like there was enough fuel getting the engine during the spin. I was hammering the gas and it just would not respond almost like it wanted to stall but it was not that bad.
Is there some safety/fail-safe feature that I don't know about or do I perhaps have an issue.
Now here is a little tid-bit that may or may not be related. A month ago I was also on the AutoX track and I noticed a few times that also during hard cornering the car hesitated (sometimes a couple of times) when I hammered the gas out of a turn. It FELT like a burp or brief stall or flood. It was suggested that I may have a crappy batch of gas (?Quicktrip?). This did NOT happen again on the track today (Chevron) - so I thought that I had solved the problem. Again - i have no idea if these issues are related but I thought it may be a clue.
Any suggestions or advice would be greatly appreciated.
Old 04-14-2013, 06:28 PM
bump
bump
Old 04-15-2013, 02:50 PM
emac's Avatar
Don't know anything about 997s but it sounds like it could be a clogged fuel filter just my 2c
Ernie 81sc
Old 04-15-2013, 02:58 PM
Senior Member
Jdub's Avatar
You may be moving oil away from the oil pump scavenge and depriving your engine of oil. That would be felt as a loss of power, and a large drop in the size of your bank account.
'78 Targa in Minerva Blue
Old 04-15-2013, 03:03 PM
Dublinoh's Avatar
Might want to ask this is the 997 forum. Foot off the brake right? Could ABS do this?
BW
ruwoodbury's Avatar
Sounds like the stability program kicking in. Some cars won't let you turn the system completely off. It will still intervene under extreme conditions--like sliding the tail way out in wet conditions.
That's my guess.
BW
1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff
Old 04-15-2013, 03:20 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I have an '05 Boxster and with PASM on and PSM off I know that I can kick the back end out and hold it. However keep in mind that under hard braking the PSM will turn itself back on for safety and I don't know what it's threshold is to turn back off. So If you are braking hard then turning the PSM may still be active even though you turned it off with the switch. If you roll from a low speed and them drop the throttle and can achieve a nice drift. I would say it's PSM kicking in.
Were you low on fuel? Maybe it was starvation.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 04-15-2013, 03:58 PM
Air Cooled
Craig_D's Avatar
My sport suspension is always engaged, and I constantly adjust the PSM settings...in my brain.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 04-15-2013, 04:07 PM
dcjones56's Avatar
Location: Living in my mind, but my tail resides in Mississippi.
2005 Carrera 997 S
When I had my 997 I was under the impression that even if you switched the Porsche Stability Management system off it would still kick in although it was in the off position. It would reactivate if the car got too carried away. At least that's what I remember. You may want to check your owner's manual.
dcjones56 - 1987 Porsche 911 Carrera - "Imogene" - very original, as per Butzi, engine rebuilt by Mr. Howard Freeman, acquired July 2010 - previous Porsche vehicles - 1998 Porsche Boxster, 2005 Porsche 997Carrera and 2009 Porsche Cayenne S.
Old 04-15-2013, 04:15 PM
This is how it works, the PSM has yaw sensors that have a predetermined amount of slip angle in them. You can drift the car or even spin the car as long as you keep your foot in the gas, but the moment the car is out of shape and you tap the brakes the PSM continues tapping the brakes.
Conversely, if you are not tapping the brake and the PSM is interupting when you get just regular wheelspin, something is wrong with your PSM. You can completely disable it by disconnecting the charge pump in the boot lid.
I find that with PSM on, the ECU will cut throttle if I get excessively sideways in my drifting efforts.
From With PSM off, is traction control realy off? - 6speedonline.com Forums
Wow. But i guess that's what you expect from an SUV/sedan company.
'77 S with '78 930 power and a few other things.
Old 04-15-2013, 05:06 PM
Eva
911SauCy's Avatar
Exactly why I have an "old" 911...car doesn't try to drive itself.
You can probably bring it to a Porsche shop that handles late model applications and have this remapped out of the PCM...or maybe not. These things are uber tech and usually encrypted so only a dealer could get in.
Old 04-16-2013, 05:12 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
I drove a pair of used 05 997s at a dealership when we were searching for our new car. Had a great saleswoman who took me out to demo PSM. With PSM on, if the rear end swung out beyond 30 degrees from the path of the car, PSM kicked in, reduced power, applied differential rear wheel braking and brought the car back in line before giving you back control of the e-throttle. With PSM off, the system would let you get the tail up to 60 degrees out of whack with the car direction before engaging by reducing power and applying differential wheel braking and bringing you back to "safe" before giving you back the throttle. Believe PSM also engages regardless of switch position of brakes are engaged hard enough to activate ABS. Awesome demo.
Old 04-16-2013, 09:40 AM
Just to be clear - there was no braking (on my part) during the spin. On the contrary, I was trying to bring the car back into line with throttle.
I am disappointed by what I am understanding from everyone. I just find it hard to believe that Porsche has restricted the ability to completely turn off stability management.
I found this video on youtube of a 997 drifting nicely. This was basically my objective. I was unable to throttle through the slide AT ALL. As soon as the car significantly kicked out, throttle was cut back.
Will it drift? Porsche 911 Carrera 997 MkI - 1080p HD - YouTube
Old 04-16-2013, 11:17 PM
speed bump!
...still waiting for some solid technical facts and/or info.
Old 04-17-2013, 06:14 PM
You do realize that this particular forum is aimed at pre-'89 911s, right? You'll find more people who know the complexities of the 997 in the 997 Area of Pelican.
'90C4
Old 04-17-2013, 06:38 PM
nineball's Avatar
the problem is your car is not old enough. i suggest something in the '78-'83 range.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 04-17-2013, 06:52 PM
didnt realize....
*** ADMIN - would it be possible to shift thread to 997 forum? I can repost at 997 but thought I would try save what is already here.
Old 04-18-2013, 11:43 PM
theiceman's Avatar
speed bump!
.... Still waiting for you to read post 5 ...... Pompus jackass
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-19-2013, 02:42 AM
DanielDudley's Avatar
Fixed it for you.
Old 04-19-2013, 04:08 AM
Hey iceman, I didn't mean to come across as a pompous jackass. It just seems that everyone was hypothesizing with no real solid facts about my situation. I am just seeking advice. I didn't mean to belittle anyone or disregard what anyone has suggested. Thank you for all of your repsonses. I apologize if it came across that way.
By the way exactly who is the pompous jackass?...Name calling on a P-forum anyway. How childish. You must be one of those very small people.
Quote de slatec2s
speed bump!
Old 04-19-2013, 11:57 PM
